I’m trying to play around with segnet and cant get the examples to work. I’ve tried several but here is one of the commands.
/segnet.py --network=/home/keith/jetson-interface-old/data/networks/FCN-ResNet18-Cityscapes-1024x512/fcn_resnet18.onnx /mnt/cifs/NAS/ImageTraining/Testing/*.jpg /mnt/cifs/NAS/ImageTraining/Testing/output_%i.jpg
The error i get is
“[TRT] INVALID_ARGUMENT: Cannot find binding of given name: data
[TRT] failed to find requested input layer data in network
[TRT] device GPU, failed to create resources for CUDA engine
[TRT] failed to create TensorRT engine for /home/keith/jetson-interface-old/data/networks/FCN-ResNet18-Cityscapes-1024x512/fcn_resnet18.onnx, device GPU
[TRT] segNet – failed to load.
jetson.inference – segNet failed to load network”
I’m not sure what the input/output blobs are for. I can provide values for them but not sure what to provide. Any suggestions?
Here’s a table of the pre-defined segmentation models that are included with the project, along with their name to use with the --network command-line argument:
BTW, for these FCN-ResNet18 ONNX models, the input blob name is input_0 and the output blob name is output_0 (these are the names of the input/output layers)
If you wanted to run the complete command manually, it should be like:
Thanks! Are there any instructions for training a custom dataset to work with segnet? I know jetson-inference/README.md at master · dusty-nv/jetson-inference · GitHub has some steps for training, will those also work for the segnet? I’ve got a custom dataset i trained but it doesnt seem to have the same input/output blobs as i get an error with those.
