hello,
I get a error on the Jetson tx2 when trying to run an segmentation part of tutorial.
when I input :./segnet-console peds-001.jpg 001.jpg --model=networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx
error appears:
segNet – loading segmentation network model from:
– prototxt: (null)
– model: networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx
– labels: (null)
– colors: (null)
– input_blob ‘data’
– output_blob ‘score_fr_21classes’
– batch_size 1
[TRT] TensorRT version 5.0.6
[TRT] loading NVIDIA plugins…
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - ONNX (extension ‘.onnx’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx.1.1.GPU.FP16.engine
[TRT] cache file not found, profiling network model on device GPU
[TRT] device GPU, loading /home/nvidia/kfr/DeepLearning/ImageRecognition/jetson-inference/build/aarch64/bin/ networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx
Input filename: networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx
ONNX IR version: 0.0.4
Opset version: 9
Producer name: pytorch
Producer version: 1.1
Domain:
Model version: 0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.4) than this parser was built against (0.0.3).
----- Parsing of ONNX model networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx is Done ----
[TRT] retrieved Input tensor “input_0”: 3x480x864
[TRT] device GPU, configuring CUDA engine
[TRT] device GPU, building FP16: ON
[TRT] device GPU, building INT8: OFF
[TRT] device GPU, building CUDA engine (this may take a few minutes the first time a network is loaded)
[TRT] device GPU, completed building CUDA engine
[TRT] network profiling complete, writing engine cache to networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx.1.1.GPU.FP16.engine
[TRT] device GPU, completed writing engine cache to networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx.1.1.GPU.FP16.engine
[TRT] device GPU, networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx loaded
[TRT] device GPU, CUDA engine context initialized with 2 bindings
[TRT] binding – index 0
– name ‘input_0’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (CHANNEL)
– dim #1 480 (SPATIAL)
– dim #2 864 (SPATIAL)
[TRT] binding – index 1
– name ‘output_0’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 5 (CHANNEL)
– dim #1 15 (SPATIAL)
– dim #2 27 (SPATIAL)
[TRT] binding to input 0 data binding index: -1
[TRT] binding to input 0 data dims (b=1 c=0 h=0 w=0) size=0
[TRT] failed to alloc CUDA mapped memory for tensor input, 0 bytes
segNet – failed to initialize.
segnet-console: failed to initialize segnet
I appreciate any help out there.
Hi, since you specified the path to the model, you need to also specify the input and output layer names:
./segnet-console peds-001.jpg 001.jpg --model=networks/FCN-ResNet18-DeepScene-864x480/fcn_resnet18.onnx --input_blob=input_0 --output_blob=output_0
Or you can simply specify the shortcut to this model, “fcn-resnet18-deepscene-864x480”, and it will automatically know the layer names:
./segnet-console peds-001.jpg 001.jpg --model=fcn-resnet18-deepscene-864x480
See this table for the other shortcut names used with segnet, you don’t need to specify the path to the build-in models:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/segnet-console-2.md#pre-trained-segmentation-models-available
hi,dusty_nv,When I try the second method:./segnet-console car1.jpeg car1resnet18_output.jpeg --network=fcn-resnet18-cityscapes-512x256 ,error appears:segnet-console: failed to initialize segnet
When I try the first method:./segnet-console peds-001.jpg 001.jpg --model=networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx --labels=networks/FCN-ResNet18-MHP-640x360/classes.txt --colors=networks/FCN-ResNet18-MHP-640x360/colors.txt --input_blob=input_0 --out_blob=output_0
He does not work either:segNet – loading segmentation network model from:
– prototxt: (null)
– model: networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx
– labels: networks/FCN-ResNet18-MHP-640x360/classes.txt
– colors: networks/FCN-ResNet18-MHP-640x360/colors.txt
– input_blob ‘input_0’
– batch_size 1
[TRT] attempting to open engine cache file networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx.1.1.GPU.FP16.engine
[TRT] device GPU, loading /home/nvidia/kfr/DeepLearning/ImageRecognition/jetson-inference/build/aarch64/bin/ networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx
Input filename: networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx
Opset version: 9
Domain:
Model version: 0
Doc string:
----- Parsing of ONNX model networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx is Done ----
[TRT] retrieved Input tensor “input_0”: 3x360x640
[TRT] network profiling complete, writing engine cache to networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx.1.1.GPU.FP16.engine
[TRT] device GPU, completed writing engine cache to networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx.1.1.GPU.FP16.engine
[TRT] device GPU, networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx loaded
– name ‘input_0’
– type FP32
– in/out INPUT
– # dims 3
– dim #1 360 (SPATIAL)
– dim #2 640 (SPATIAL)
– name ‘output_0’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 21 (CHANNEL)
– dim #1 12 (SPATIAL)
– dim #2 20 (SPATIAL)
[TRT] binding to input 0 input_0 binding index: 0
[TRT] binding to input 0 input_0 dims (b=1 c=3 h=360 w=640) size=2764800
[TRT] binding to output 0 score_fr_21classes binding index: -1
[TRT] binding to output 0 score_fr_21classes dims (b=1 c=0 h=0 w=0) size=0
[TRT] failed to alloc CUDA mapped memory for tensor output, 0 bytes
All models are placed inside the networks like this:
nvidia@nvidia:~/kfr/DeepLearning/ImageRecognition/jetson-inference/data/networks$ ll
total 166276
drwxr-xr-x 23 nvidia nvidia 4096 Oct 18 08:54 ./
drwxr-xr-x 4 nvidia nvidia 4096 Sep 23 23:02 ../
drwxr-xr-x 2 nvidia nvidia 4096 Oct 17 04:19 20191016-145253-52f9_epoch_30.0/
-rw-r–r-- 1 nvidia nvidia 53533754 Jun 18 13:57 bvlc_googlenet.caffemodel
-rw-r–r-- 1 nvidia nvidia 17797624 Oct 17 21:03 bvlc_googlenet.caffemodel.1.1.GPU.FP16.engine
-rw-rw-r-- 1 nvidia nvidia 159 Aug 16 14:44 classes.txt
-rw-r–r-- 1 nvidia nvidia 229 Sep 4 15:18 colors.txt
drwxrwxr-x 2 nvidia nvidia 4096 Oct 17 22:44 DetectNet-COCO-Airplane/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 14 23:43 DetectNet-COCO-Bottle/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 14 23:15 DetectNet-COCO-Dog/
drwxrwxr-x 2 nvidia nvidia 4096 Sep 24 23:48 facenet-120/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 17 04:08 FCN-Alexnet-Aerial-FPV-720p/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 17 23:05 FCN-Alexnet-Cityscapes-HD/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 17 05:49 FCN-Alexnet-Cityscapes-SD/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 18 04:04 FCN-Alexnet-Pascal-VOC/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 17 23:16 FCN-Alexnet-SYNTHIA-Summer-HD/
drwxrwxr-x 2 nvidia nvidia 4096 Sep 4 15:29 FCN-ResNet18-Cityscapes-1024x512/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 18 07:29 FCN-ResNet18-Cityscapes-2048x1024/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 18 21:18 FCN-ResNet18-Cityscapes-512x256/
drwxrwxr-x 2 nvidia nvidia 4096 Sep 16 13:23 FCN-ResNet18-DeepScene-576x320/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 18 08:44 FCN-ResNet18-DeepScene-864x480/
drwxrwxr-x 2 nvidia nvidia 4096 Oct 18 21:15 FCN-ResNet18-MHP-640x360/
drwxr-xr-x 3 nvidia nvidia 4096 Oct 18 07:14 ‘FCN-ResNet18-MHP-640x360 (1)’/
-rw-rw-r-- 1 nvidia nvidia 47137244 Aug 21 13:33 fcn_resnet18.onnx
-rw-r–r-- 1 nvidia nvidia 51577848 Oct 18 07:02 fcn_resnet18.onnx.1.1.GPU.FP16.engine
drwxrwxr-x 2 nvidia nvidia 4096 Aug 30 14:44 FCN-ResNet18-SUN-RGBD-640x512/
drwxr-xr-x 3 nvidia nvidia 4096 Oct 18 07:14 ‘FCN-ResNet18-SUN-RGBD-640x512 (1)’/
drwxr-xr-x 2 nvidia nvidia 4096 Oct 17 21:11 GoogleNet/
-rw-r–r-- 1 nvidia nvidia 35776 Jun 18 13:57 googlenet_noprob.prototxt
-rw-r–r-- 1 nvidia nvidia 35861 Jun 18 13:57 googlenet.prototxt
-rw-r–r-- 1 nvidia nvidia 31675 Jun 18 13:53 ilsvrc12_synset_words.txt
what I should do now?Thanks for your help.
when I input this:./segnet-console --model=fcn-resnet18-cityscapes peds-001.jpg output.jpg
Displayed on the screen:
– prototxt: (null)
– model: fcn-resnet18-cityscapes
– labels: (null)
– colors: (null)
– input_blob ‘data’
– batch_size 1
[TRT] detected model format - custom (extension ‘.fcn-resnet18-cityscapes’)
[TRT] model format ‘custom’ not supported by jetson-inference
hi,dusty。I solved this problem by recompiling the project and the results look pretty good.
OK thanks, glad you got it working. Just FYI, I noticed in the command you posted above you used --out-blob (when it should be --output-blob), so that is why it may not have been working at the time:
# --out_blob incorrect
# should have been --output_blob=output_0
./segnet-console peds-001.jpg 001.jpg --model=networks/FCN-ResNet18-MHP-640x360/fcn_resnet18.onnx --labels=networks/FCN-ResNet18-MHP-640x360/classes.txt --colors=networks/FCN-ResNet18-MHP-640x360/colors.txt --input_blob=input_0 --output_blob=output_0
