I’m trying to set a conditional breakpoint, but the condition depends on a local device variable. So I put ‘set breakpoint pending on’ in the gdb script. I also put ‘show breakpoint pending’ right after it, and the setting is actually on.
Using --command to load the gdb script results in ‘No symbol “i” in current context.
Make conditional breakpoint pending on future shared library load? (y or [n]) [answered N; input not from terminal]’
If I remove the condition, the breakpoint is used correctly.
If I manually add the breakpoint before running, and answer yes on whether gdb should make the breakpoint pending, it works correctly.
The old GCC or Ubuntu could explain it.
Setup:
CUDA 7.5, gcc 4.9.2, Ubuntu 7.9
Compile command:
nvcc -G -g main.cu
Debug command:
cuda-gdb a.out --command script_gdb
Script:
break main.cu:8 if i == 3
run
main.cpp:
#include <stdio.h>
__global__ void kernel(double *x){
double sum = 0.0;
for(int i = 0; i < 5; ++i){
sum += x[i];
x[0] = sum;
int main(){
double x[] = {1, 2, 3, 4, 5}, *d_x;
cudaSetDevice(0);
cudaMalloc((void**)&d_x, sizeof(double)*5);
cudaMemcpy(d_x, x, sizeof(double)*5, cudaMemcpyHostToDevice);
kernel<<<1, 1>>>(d_x);
cudaDeviceSynchronize();
cudaMemcpy(x, d_x, sizeof(double)*5, cudaMemcpyDeviceToHost);
printf("x[%d]: %f\n", i, x[i]);
cudaFree(d_x);
return 0;
cuda-gdb output:
Reading symbols from /home/test/a.out...done.
Debugger's behavior regarding pending breakpoints is on.
No symbol "i" in current context.
