ok so I started this post over at hardforum.com but figured … why wouldn’t I put it there???
Ok so I’m new to this and I have a test lab at work.
I have 4 esxi boxes - will get to them later
a windows 10 pc (dell precision 5810)
Our guys were getting rid of a mess of hardware so I grabbed it and figured time to play around.
I stuck a mellanox card in the win10 box and drivers installed, albeit, MS drivers. but it seems to be good?
I also connected a cable to the switch and the light on the switch lit up but in win10 the NIC says cable unattached.
switch - Flextronics F-x430066 8 Port 4x SDR Infiniband
cable - Mellanox Mcc4l30-300 Microgigacn Latch 0.3 M Infiniband Cable
cards - HPE InfiniBand 4X DDR Conn-X PCI-E G2 Dual Port HCA (483514-B21)
so few questions…
- what is needed on win10 side other than what I have done?
- if I put another card in a secondary pc, and just attach both to the switch, just give static IP’s and that is it?
ill just start with them…thx
So over there I have pics. I cant put pics here so a bit harder…
Ill add it here by copying the text…
in Windows 10 dev manager - shows using Microsoft drivers
ipoib6x.sys - 4/25/2018 ver. 5.50.14643.0
C:>mst status -v
MST devices:
mt26418_pci_cr0 bus:dev.fn=01:00.0
mt26418_pciconf0 bus:dev.fn=01:00.0
C:>mlxfwmanager -d mt26418_pci_cr0 --query
Querying Mellanox devices firmware …
FATAL - Can’t find device id.
Device #1:
Device Type: N/A
Part Number: –
Description:
PSID:
PCI Device Name: mt26418_pci_cr0
Port1 MAC: N/A
Port1 GUID: N/A
Port2 MAC: N/A
Port2 GUID: N/A
Versions: Current Available
FW –
Status: Failed to open device
