Device: MSI C931 EdgExpert-C594
OS: Nvidia DGX OS GA2 OTA2
Network Environment: UniFi Dream Machine SE & US XG 6 PoE Switch
Fresh out of the box, I am stuck in the initial setup wizard. Even with a 10GbE RJ45 cable connected before boot and assigned IP on Port via DHCP, the installer fails to “Skip” the Wi-Fi selection screen.
I choose (language/ region, accept terms, create user/ pw) but the next screen “Connect to Wi-Fi” fails to proceed to next step. When attempting to join any Wi-Fi network (including mobile hotspots), it returns “Unable to join. Fail to join the network. Please try again.”
Despite the UI saying there is no connection, the backend is clearly online:
* I can successfully ping the unit (10.0.10.5) from my desktop with 3ms latency.
* The UniFi dashboard logs confirms a stable 10GbE Full Duplex link on Port 2 (VLAN 10).
* UniFi “Latest Flows” shows the device successfully reaching connectivity-check.ubuntu.com and dashboard.snapcraft.io via HTTPS.
* System clock/ date is verified correct. IPv4 is visible but shows “Configured: Disabled” in the UEFI Network Stack, while the OS has clearly grabbed a DHCP lease.
Attempting to drop to a TTY (Ctrl+Alt+F2) triggers an immediate system reboot.
Lastly i tried installing the latest OS release “Nvidia DGX OS GA2 OTA2”.
Any support on how I should test this issue further, currently have an expensive paperweight on my desk for 3days now.?
