my pipeline is as follows:
nvstreammux → pgie → tracker → sgie → (sgie_nvdsanalytics_srcpad) nvdsanalytics → nvvidconv → tiler → nvosd → renderer
the pgie model is peoplenet, which has the following config file [note that I intend to only detect faces]:
[property]
# workspace-size=3048
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=../models/peoplenet/resnet34_peoplenet_pruned.etlt
labelfile-path=../configs/labels_peoplenet.txt
model-engine-file=../models/peoplenet/resnet34_peoplenet_pruned.etlt_b1_gpu0_int8.engine
int8-calib-file=../models/peoplenet/resnet34_peoplenet_int8.txt
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=1
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=3
cluster-mode=1
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
# output-tensor-meta=1
[class-attrs-0]
pre-cluster-threshold=1.4
## Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=1
[class-attrs-1]
eps=0.7
minBoxes=1
[class-attrs-2]
pre-cluster-threshold=0.4
eps=0.5
minBoxes=1
The sgie model is a onnx model to classify the age of the detected faces, and has the following configurations:
[property]
workspace-size=3048
gpu-id=0
net-scale-factor=1
onnx-file=../models/age/age_googlenet.onnx
model-engine-file=../models/age/age_googlenet.onnx_b1_gpu0_fp32.engine
# force-implicit-batch-dim=1
input-dims=3;224;224;0
# offsets=104;117;123
offsets=123;117;104
batch-size=1
# 0=FP32 and 1=INT8 mode
network-mode=0
input-object-min-width=0
input-object-min-height=0
process-mode=2
# model-color-format=1
gpu-id=0
gie-unique-id=2
# operate-on-gie-id=1
# operate-on-class-ids=0
network-type=100
# is-classifier=1
output-blob-names=fc1
# classifier-async-mode=1
# classifier-threshold=0.001
#scaling-filter=0
#scaling-compute-hw=0
my sgie probe function is as follows:
def sgie_src_pad_buffer_probe(pad,info,u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
found_infer_data = False
while l_frame is not None:
try:
except StopIteration:
break
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
# print(dir(obj_meta))
break
l_user = obj_meta.obj_user_meta_list
while l_user is not None:
try:
user_meta=pyds.NvDsUserMeta.cast(l_user.data)
break
if user_meta.base_meta.meta_type != pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META:
continue
found_infer_data = True
tensor_meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
layers_info = []
# print(f"num out layers: {tensor_meta.num_output_layers}", flush=True)
# print(f"gpu id: {tensor_meta.gpu_id}")
# print(f"unique id: {tensor_meta.unique_id}")
ageList=['(0-2)', '(4-6)', '(8-12)', '(15-20)', '(25-32)', '(38-43)', '(48-53)', '(60-100)']
for i in range(tensor_meta.num_output_layers):
layer = pyds.get_nvds_LayerInfo(tensor_meta, i)
layers_info.append(layer)
try:
l_user = l_user.next
break
if found_infer_data:
for layer in layers_info:
# Convert NvDsInferLayerInfo buffer to numpy array
ptr = ctypes.cast(pyds.get_ptr(layer.buffer), ctypes.POINTER(ctypes.c_float))
v = np.ctypeslib.as_array(ptr, shape=(len(ageList),))
classifier_meta = pyds.nvds_acquire_classifier_meta_from_pool(batch_meta)
classifier_meta.unique_component_id = tensor_meta.unique_id
label_info = pyds.nvds_acquire_label_info_meta_from_pool(batch_meta)
label_info.result_class_id = np.argmax(v)
label_info.result_prob = np.max(v)
label_info.result_label = ageList[np.argmax(v)]
obj_meta.text_params.display_text = f"{obj_meta.obj_label} {obj_meta.object_id} {label_info.result_label}"
pyds.nvds_add_label_info_meta_to_classifier(classifier_meta, label_info)
pyds.nvds_add_classifier_meta_to_object(obj_meta, classifier_meta)
else:
print(f"no infer data found for: {obj_meta.object_id}")
print(f"{[obj_meta.tracker_bbox_info.org_bbox_coords.left, obj_meta.tracker_bbox_info.org_bbox_coords.top, obj_meta.tracker_bbox_info.org_bbox_coords.width, obj_meta.tracker_bbox_info.org_bbox_coords.height]}")
obj_meta.text_params.display_text = f"{obj_meta.obj_label} {obj_meta.object_id} ---"
try:
l_obj=l_obj.next
break
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
an example of the unexpected output that I get:
no infer data found for: 32
[48.4701042175293, 189.16497802734375, 13.985758781433105, 25.6199893951416]
no infer data found for: 33
[115.42562103271484, 191.5161590576172, 9.979028701782227, 22.19746971130371]
[48.4632682800293, 189.09146118164062, 13.934600830078125, 25.54955291748047]
[115.44075012207031, 191.4876251220703, 9.941106796264648, 22.13165283203125]
no infer data found for: 65
[36.47920227050781, 183.53929138183594, 12.897473335266113, 27.13695526123047]
The Issue
So what happens is that most of the detected faces are classified with the sgie model but some of them are not. Which is not what I expect, as I want to classify every detected face.
I have noticed that the faces that do not get infered by sgie are often small in size, that’s why I printed their bbox info, and I made sure to add input-object-min-width=0 and input-object-min-height=0 to the sgie model configs but that didn’t change anything.
GPU
• DeepStream Version
v5.1
• TensorRT Version
the one on the deepstream devel docker image
465.19.01
questions
