When assigning shared memory in a kernel, if the kernel has many blocks,
which streaming processor allocates this shared memory?
Or, do all the streaming processors running this kernel allocate this shared memory?
Thank you.
Thank you.
Each block allocates a new shared memory region when it begins executing. It deallocates it when it finishes executing.
The shared memory region is allocated on the streaming processor that the block executes on.
