Shared memory and multiple blocks
Hi Everyone,
When I use shared memory within a kernel, is the shared memory variable created for each block of threads?
For example:
__global__ void SOMEKERNEL(double *a, double *b)
     __shared__ double c[512];
Does each block get c[512]? So if I had 10 blocks, would there be 10 copies of c[512]? Each of which I could load with data from global memory…? I’m trying to implement the reduction code from the SDK in one of my kernels, but my program is crashing and I want to make sure I’ve understood how using shared memory works.
Thanks in advance to any help!
Yes, each running block gets its own set of shared memory variables.
Great, thanks!
