Hi
I’m a little bit confused as to how the shared memory is organised in a kernel which uses multiple blocks. If I define a set amount of shared memory when I run the kernel (as in the execution parameters) is that the total amount of shared memory or is that the shared memory per block?
Kind regards
Danny Schofield
