Seeing segfault when running a simple pipeline:
$ gst-launch-1.0 -v nvv4l2h264enc v4l2src device=/dev/video0
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Caught SIGSEGV
^C
But works fine if I change element order (complains about the bad pipeline but doesn’t segfault):
$ gst-launch-1.0 -v v4l2src device=/dev/video0 nvv4l2h264enc
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-linked (-1)
Execution ended after 0:00:00.999081338
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
So I can conclude:
gst-launch-1.0 -v nvv4l2h264enc v4l2src device=/dev/video0 # segfault
gst-launch-1.0 -v v4l2src device=/dev/video0 nvv4l2h264enc # works
gdb bt:
(gdb) bt
#0 0x0000007fb302f090 in () at /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so
#1 0x0000007fb302ff9c in () at /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so
#2 0x0000007fb302e8f8 in () at /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so
#3 0x0000007fb302e6b8 in () at /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so
#4 0x0000007fb7364b20 in () at /usr/lib/aarch64-linux-gnu/libv4l2.so.0
#5 0x0000007fb73606c0 in v4l2_fd_open () at /usr/lib/aarch64-linux-gnu/libv4l2.so.0
#6 0x0000007fb33d363c in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so
#7 0x000000555582e230 in ()
• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version deepstream-5.0/stable,now 5.0.1-1 arm64 [installed]
• JetPack Version (valid for Jetson only) nvidia-l4t-core 32.5.1-20210519111140
• TensorRT Version tensorrt/stable,now 7.1.3.0-1+cuda10.2 arm64 [installed]
$ cat /etc/os-release
NAME="Ubuntu"
VERSION="18.04.5 LTS (Bionic Beaver)"
Same after upgrading nvidia-l4t-* to 32.5.2-20210709090156.
What is incorrect in your opinion? I can connect elements into a pipeline but it segfaults even without connections.
Please refer to gstreamer pipeline concept. You need to learn the concept and proper usage of “gst-launch”. It has nothing to do with deepstream or any Jetson component.
So, you mean that I can create a pipeline with gst-launch-1.0 that can legitimately segfault in libv4l2_nvargus.so?
Let me give more context. We have a pipeline working in the production on dGPUs but this pipeline segfaults on Jetson Xavier NX. I simplify this pipeline to a minimal case to ask here for help. This simplified version of the pipeline continues to segfault but it must NOT segfault. I don’t post a full-featured pipeline because it has lots of unrelated details.
If you can give me a debug version of libv4l2_nvargus.so, I can run in gdb and look where it crashes.
Your gst-alunch pipeline is wrong. It has nothing to do with any HW or SW. Please use gst-launch in the right way.
Please make sure you are familiar with gstreamer before you start with deepstream.
So it is expected that it segfaults in libv4l2_nvargus.so, correct?
@Fiona.Chen I’ve created another pipeline that works at one device but segfaults on another:
$ gst-launch-1.0 -v nvvideoconvert name=encode1_input ! nvv4l2h264enc ! fakesink v4l2src device=/dev/video0 ! decodebin ! videoconvert ! encode1_input.
Caught SIGSEGV
Is this pipeline also “wrong”?
Why do you always run a “broken” pipeline?
Do you know a pipeline should start with source and end with sink?
Have you used “v4l2-ctl” to list your camera’s output formats before you use gstreamer to access it? Why do you use “decodebin” here?
How much do you know about gstreamer? Please learn gstreamer basic knowledge and skills before you start with deepstream. This is deepstream forum. We only focus on deepstream topics here. I’ve listed the gstreamer documents you can refer to in previous posts.
Your issue has nothing to do with deepstream.
It starts with v4l2src and ends with fakesink.
If I don’t know much about GStreamer then why my “broken” pipeline works on another setup with dGPU:
$ gst-launch-1.0 nvvideoconvert name=encode1_input ! nvv4l2h264enc ! fakesink v4l2src device=/dev/video0 ! decodebin ! videoconvert ! encode1_input.
How much do YOU know about gstreamer?
What is the result of “v4l2-ctl -d /dev/video0 --list-formats-ext”?
If your camera can output MJPEG video, please upgrade to DS 6.0 GA version first. There are some nvvideoconvert bug fixed.
Only for this pipeline. If your camera can output MJPEG video, please upgrade to DS 6.0 GA version first. There are some nvvideoconvert bug fixed.
Thanks, will try to upgrade DS6.0 and will post back.
The camera can output MJPG:
$ v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Index : 1
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.008s (120.000 fps)
Interval: Discrete 0.011s (90.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 2560x1440
Size: Discrete 3840x2160
Size: Discrete 4096x2160
Index : 2
Pixel Format: 'NV12'
