Hey. So i have been playing with CUDA for a while now and everything has been working but today i have some issues with running even the simplest programs.
Could you guys verufy for me why the following program is printing rubbish to the console.
The idea of the program: i pass in an array to the kernel. Then in kernel, in each thread writes to it its threadIdx.x and threadIdx.y and i copy the array back and
see its contents. However, when im printing it back i get some ridiculous numbers like -2343243234 etc.
The call makes use of 1 block and 9 x 3 threads therefore the array is of size 2 * 9 * 3.
Any help or explanation is appreciated. Thanks.
#include <iostream>
using namespace std;
__global__ void see_y_threads(int a[],int size)
int tx = threadIdx.x;
int ty = threadIdx.y;
int tid = tx * size + ty;
a[tid] = threadIdx.x;
a[tid + 27] = threadIdx.y;
int main()
int* dev_a;
const int N = 27;
int a[2 * N];
//zero out the array
for(int i=0; i < 2*N; i++) a[i] = 0;
cudaMalloc((void**) &dev_a, 2 * N * sizeof(int));
cudaMemcpy(dev_a,a, 2 * N * sizeof(int), cudaMemcpyHostToDevice);
//call
dim3 block(9,3,1);
see_y_threads<<<1, block>>>(a,9);
cudaMemcpy(a, dev_a, 2 * N * sizeof(int), cudaMemcpyDeviceToHost);
for(int i=0; i < N; i++)
cout << a[i] << "\t" << a[i+N] <<endl; // < -- printing rubbish
cudaFree(dev_a);
cin.get();
return 0;
#include <iostream>
int main()
int* dev_a;
const int N = 27;
int a[2 * N];
//call
dim3 block(9,3,1);
cudaFree(dev_a);
cin.get();
return 0;
threadIdx provides the ID numbers of a thread within a block. Assuming the kernel is launching (which you only know if you check the return codes from the CUDA functions), the reason you see all zeros is because you are launching the kernel with a configuration of 1 thread per block, and 27 blocks. With only 1 thread per block, threadIdx.x and threadIdx.y will be 0 for every thread.
