Simulating Robotiq 144mm Gripper with Franka Arm
How do I replace Franka default gripper with Robotiq Gripper 144mm in the Franka Arm?
Gripper URDF: link
The URDF contains a mimic joint which IssacGym doesn’t support, hence importing this through URDF throws a mapAt:error.
How to resolve this issue and use this gripper with Franka?
Hi, you can try using 2 usd files from isaac sim assets and use robot assembler function to join.
