**• Hardware Platform -------------> GPU
**• DeepStream Version -----------> 7.1 • TensorRT Version ---------------> 10.8.7
When I am giving one pgie with interval = 0 and another pgie with interval=3 tracker only tracking one of two. When
both interval is same working as expected . How to solve this issue ?
Do you mean nvtracker only tracking the object of the second PGIE? Can you print the frame_meta->bInferDone in NvDsBatchMeta->NvDsFrameMeta? Are you using NvDCF tracker? Which nvtracker configure are you using? Can you share the configure file of the DeepStream application?
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
