Smart Record "refused renegotiation to video/x-h264"
Jetson Xavier NX Developer Kit
• DeepStream Version
4.5.2 [L4T 32.5.1]
• TensorRT Version
We are running a Deepstream app, and triggering smart record from within Deepstream via a probe function when certain objects are detected within the frame.
Smart Record is working without issue when we stream on 1920x1080p RTSP streams, with the following characteristics (taken from ffprobe):
  • Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 5 fps, 50 tbr, 90k tbn, 5 tbc
However, when we run the Deepstream application with the following stream:
Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 2304x1296 [SAR 1:1 DAR 16:9], 6 fps, 50 tbr, 90k tbn, 12 tbc
We see the following error:
2021-12-21T09:55:52.171Z  **PERF:  4.97 (5.00)     4.95 (5.00)     5.35 (6.62).  2021-12-21T09:55:56.348Z  WARNING from mux_elem2: Can't change input format at runtime..  2021-12-21T09:55:56.349Z  Debug info: gstqtmux.c(5757): gst_qt_mux_video_sink_set_caps (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstBin:record_bin2/GstBin:enc_bin2/GstQTMux:mux_elem2:.  2021-12-21T09:55:56.349Z  pad video_0 refused renegotiation to video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d0032ffe1002f674d00329a650120051ff80b7010101400000fa000023283a1800ec40003b0daef2e343001d88000761b5de5c2800001000568ee3c8000, level=(string)5, profile=(string)main, pixel-aspect-ratio=(fraction)1/1, width=(int)2304, height=(int)1296, framerate=(fraction)18/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true.  2021-12-21T09:55:56.355Z  WARNING from mux_elem2: Can't change input format at runtime..  2021-12-21T09:55:56.356Z  Debug info: gstqtmux.c(5757): gst_qt_mux_video_sink_set_caps (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstBin:record_bin2/GstBin:enc_bin2/GstQTMux:mux_elem2:.  2021-12-21T09:55:56.357Z  pad video_0 refused renegotiation to video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d0032ffe1002f674d00329a650120051ff80b7010101400000fa000023283a1800ec40003b0daef2e343001d88000761b5de5c2800001000568ee3c8000, level=(string)5, profile=(string)main, pixel-aspect-ratio=(fraction)1/1, width=(int)2304, height=(int)1296, framerate=(fraction)18/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true.  2021-12-21T09:55:56.777Z  NvMMLiteOpen : Block : BlockType = 261.  2021-12-21T09:55:56.778Z  NVMEDIA: Reading vendor.tegra.display-size : status: 6.  2021-12-21T09:55:56.781Z  NvMMLiteBlockCreate : Block : BlockType = 261.  2021-12-21T09:55:56.786Z  Opening in BLOCKING MODE.  2021-12-21T09:55:56.786Z  Opening in BLOCKING MODE.  2021-12-21T09:55:57.170Z  **PERF:  5.04 (5.00)     5.05 (5.00)     11.59 (6.71).  2021-12-21T09:56:02.170Z  **PERF:  5.01 (5.00)     4.97 (5.00)     18.46 (6.92).  2021-12-21T09:56:03.457Z  NvMMLiteOpen : Block : BlockType = 261.  2021-12-21T09:56:03.458Z  NVMEDIA: Reading vendor.tegra.display-size : status: 6.  2021-12-21T09:56:03.463Z  Opening in BLOCKING MODE.  2021-12-21T09:56:03.463Z  Opening in BLOCKING MODE.  2021-12-21T09:56:03.468Z  NvMMLiteBlockCreate : Block : BlockType = 261.  2021-12-21T09:56:07.172Z  **PERF:  4.99 (5.00)     5.04 (5.00)     8.03 (6.93).
Stream-mux is configured as follows:
[streammux]
gpu-id = 0
live-source = 1
batch-size = 1
batched-push-timeout = 40000
width = 1920
height = 1080
enable-padding = 0
nvbuf-memory-type = 0
Are there any resolution restrictions on smart-record?
NA
Smart record works with compressed video, resolution do not impact anything.
It is qtmux refused negotiation but not nvstreammux. qtmux
You can try with “gst-launch” command line to check whether the ES in your RTSP stream can be supported by qtmux. It is a pure gstreamer issue, it has nothing to do with deepstream.
Thanks for the prompt reply. Could you suggest a command using qtmux that would diagnose the issue?
Please google for the qtmux pipeline
https://coderedirect.com/questions/610305/gstreamer-1-0-saving-rtsp-stream-to-file
