**• Hardware Platform (GPU) RTX 3060
**• DeepStream Version 6.0
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only) CUDA11.7
• Issue Type (questions)
您好,想請問一下使用 Smart Video Record錄影的時候,當下的串流影像是不是就不會繼續存在smart-rec-cache裡面?
因為我發現我在進行連續錄影的時候,剛剛錄過的影像就沒辦法被smart-rec-start-time所設定的時間錄到。
當我設定smart-rec-start-time=60時
假設我第一次錄影的時段為8:00:00-8:30:00
第二次錄影的時段為8:30:00開始
連續錄影的狀態下我只能錄到8:30:00開始的影像
而無法錄影到8:29:00開始的影像
類似於以下網站的問題,請問現在有改善或有辦法修改嗎?
• Hardware Platform Jetson
• DeepStream Version 5.0
• JetPack Version 4.5
• TensorRT Version 7
I’ve been doing some development with Deepstream and have successfully hooked up the smart record function to MIPI/USB cameras. That is not my complaint.
My issue is that the documentation for Smart Record doesn’t make clear there are some major limitations in Smart Record. Specifically, (and I’m guessing this is because it uses a Gstreamer Queue as it’s method of buffering) that once a smar…
fanzh
December 30, 2022, 3:15am
3
• TensorRT Version
• TensorRT Version
fanzh
January 3, 2023, 10:33am
5
could you share the parameters when calling NvDsSRStart? could you use deepstream-testsr to reproduce this issue?
[source0]
smart-record=1
smart-rec-dir-path=/testconfig_output/
#smart-rec-file-prefix=smart_record
smart-rec-cache=120
smart-rec-container=0
smart-rec-default-duration=60
smart-rec-duration=60
smart-rec-interval=10
code:
NvDsSRSessionId sessId = 0;
guint startTime = 60;
guint duration = 100;
const char *str2 = “car”;
//= TimeUtils::currentTimeInMillis();
// std::cout << "1…>>>>>>>------------------->smart_rec_cache_size: " << src_bin->config->smart_rec_cache_size << “\n”;
int64 smartRecord_timestamp = TimeUtils::currentTimeInMillis();
if (src_bin->config->smart_rec_duration >= 0)
duration = src_bin->config->smart_rec_duration;
if (src_bin->config->smart_rec_start_time >= 0)
startTime = src_bin->config->smart_rec_start_time;
NvDsSRStart(ctx, &sessId, startTime, duration, NULL);
透過deepstream-testsr
假使我第一次錄影為09:00開始錄
錄影的容容為8:59到9:01
第二次的錄影的時間為09:01開始
內容卻只有9:01-9:02,理論上應該要是9:00到9:02
fanzh
January 5, 2023, 6:41am
8
thanks for your report, this overlapped smart record requirement is under development.
