Note: Went back to 364 drivers; major issues with 378 drivers for things that work fine with 364…
System hangs hard if I connect an external monitor (even REISUB doesn’t work) while running, and seems to hang in the same way if I boot with the monitor already connected. That’s a dealbreaker.
System hangs at black screen when resuming from suspend. Trying to resume from hibernate ended with segfault.
Right after booting, something keeps causing repeated system freezes (cursor won’t move) for several minutes… looked like it might be due to a kworker thread when I looked at top. Eventually stops, but doesn’t happen at all when using 364.
System hangs hard at login if prime-select is switched to intel driver - even after complete reboot. Not sure if that’s an nVidia problem or something new with the intel driver since I haven’t used it in a while.
These hard hangs make it doubtful I’m going to be able to remote in and collect any bug reports, but I’ll give it a shot whenever I get the time.
