Myzhar
May 30, 2020, 11:23am
1
Hi all,
I’m trying to change the default buffer size of the Jetson Nano using the following procedure
$ sudo su
# cd /sys/module/spidev/parameters
# chmod 666 bufsiz
# echo 65534 > bufsiz
but I get the error
bash: echo: write error: Input/output error
For my application I need a SPI buffer of more than 20480 byte.
Any idea?
Thank you
Walter
I found a good solution that I want to share with the community.
There are two easy way to set the size of the SPI buffer, one temporary and one permanent:
Temporary
First of all remove the spidev module from the Kernel:
$ sudo rmmod spidev
then reload it with the required parameter
$ sudo modprobe spidev bufsize=20480
when you reboot the Jetson Nano the value of the size of the SPI buffer will be restored to the default value, i.e. 4096B
Permanent
To permanently set the value of the size of the SPI buffer you must create a configuration file for modprobe
$ sudo nano /etc/modprobe.d/spidev.conf
Enter the following line
options spidev bufsiz=20480
Save and reboot the Jetson Nano
Check the parameter
You can check that the parameter is correcly set using the command
$ cat /sys/module/spidev/parameters/bufsiz
that should output the value of the size of the buffer that you chose, i.e. 20480
Hello Myzhar;
I tried your solution;i found 2 questions;
1:in temporary solution;
this command may be failed;
it should be :
$ sudo modprobe spidev bufsiz=20480
2:i do not find /etc/modprobe.d/spidev.conf this node in my jetson nano;
