I am currently writing a small program for on the Jetson TK1 board, to display some images.
Therefore I have to use OpenCV. The good thing is that the Jetpack R21.2 comes with an OpenCV library for Tegar, which is in ~/OpenCVTegra. In this folder is the libopencv4tegra-repo_l4t-r21_2.4.10.1_armhf.deb and a script to install it.
So far, so good.
Then I wrote the CMakeLists:
set(ProjectName "PfeDxReceiver")
project(${ProjectName})
cmake_minimum_required(VERSION 2.8.10)
# OpenCV
if(WITH_DispImg)
find_package(OpenCV 2.4.10 REQUIRED)
include_directories(${OpenCV_INCLUDE_DIR})
link_directories(${OpenCV_LINK_DIRECTORIES})
# Definition for the program
add_definitions(-D_USE_OPENCV)
message("opencv: inc:${OpenCV_INCLUDE_DIR},
link:${OpenCV_LINK_DIRECTORIES},
lib:${OpenCV_LIBRARIES}")
endif()
When I ran the cmake-gui and press configure I get the following error:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
OpenCV_CONTRIB_LIBRARY (ADVANCED)
linked by target “PfeDxReceiver_bin” in directory /media/ubuntu/9C33-6BBD/Develop/PfeDxReceiver
OpenCV_CORE_LIBRARY (ADVANCED)
… strange…
So I did some research:
Usually the libs are under: /usr/lib/
but there aren’t any opencv libraries…
with
pkg-config --libs opencv
I get the following result:
/usr/lib/libopencv_calib3d.so /usr/lib/libopencv_contrib.so /usr/lib/libopencv_core.so /usr/lib
/libopencv_features2d.so /usr/lib/libopencv_flann.so /usr/lib/libopencv_gpu.so /usr/lib
/libopencv_highgui.so /usr/lib/libopencv_imgproc.so /usr/lib/libopencv_legacy.so /usr/lib
/libopencv_ml.so /usr/lib/libopencv_objdetect.so /usr/lib/libopencv_photo.so /usr/lib
/libopencv_stitching.so /usr/lib/libopencv_superres.so /usr/lib/libopencv_ts.a /usr/lib
/libopencv_video.so /usr/lib/libopencv_videostab.so /usr/lib/libopencv_esm_panorama.so /usr/lib
/libopencv_facedetect.so /usr/lib/libopencv_imuvstab.so /usr/lib/libopencv_tegra.so /usr/lib
/libopencv_vstab.so -lcufft -lnpps -lnppi -lnppc -lcudart -lrt -lpthread -lm -ldl
looks good to me.
find_package(opencv …) finds the following dirs:
inc:/usr/include/opencv
link:
lib:OpenCV_CONTRIB_LIBRARY-NOTFOUND;OpenCV_CORE_LIBRARY-NOTFOUND;OpenCV_FEATURES_LIBRARY-NOTFOUND;OpenCV_FLANN_LIBRARY-NOTFOUND;OpenCV_GPU_LIBRARY-NOTFOUND;OpenCV_HAARTRAINING_LIBRARY-NOTFOUND;OpenCV_HIGHGUI_LIBRARY-NOTFOUND;OpenCV_IMGPROC_LIBRARY-NOTFOUND;OpenCV_LEGACY_LIBRARY-NOTFOUND;OpenCV_ML_LIBRARY-NOTFOUND;OpenCV_NONFREE_LIBRARY-NOTFOUND;OpenCV_OBJDETECT_LIBRARY-NOTFOUND;OpenCV_PHOTO_LIBRARY-NOTFOUND;OpenCV_STITCHING_LIBRARY-NOTFOUND;OpenCV_TS_LIBRARY-NOTFOUND;OpenCV_VIDEO_LIBRARY-NOTFOUND;OpenCV_VIDEOSTAB_LIBRARY-NOTFOUND
When I ran a search for e.g. libopencv_highgui.so, it is located in /usr/lib.
Can it be that the Tegra specific version of OpenCV is not correctly supported with Cmake?
Custom-native compilation is not an option, described here:
http://elinux.org/Jetson/Installing_OpenCV#Getting_to_know_OpenCV
Cause:
“Note: Compiling OpenCV from source will not give you NVIDIA’s CPU optimizations that are only available in the closed-source prebuilt OpenCV4Tegra packages.”
Q1: What is wrong here?
Q2: Should I create the path variables for OpenCV stuff manually, in case I am building the project on the Tegra (It must support multiple platforms)? What would you recommend me?
Thank you in advance,
KR,
Roland
