Hello, i’m a french linuxian on Linux mint 18 ans i can’t use my GTX geforce 950… i installed drivers to use or but that didn’t work…
Somebody Can help me?
Please run nvidia-bug-report.sh as root and attach the tar.gz file it creates to your post.
It said that the command “nvidia-bug-report.sh” doesn’t exist…
Maybe I forgot to install a package or something like that?
You probably installed the mint package, then it’s in
/usr/lib/nvidia-XXX/bin/
with XXX being the version of the driver
[b]In “/usr/lib/nvidia-384/bin/”
i’ve got that:
[/b]
baboulinux@baboulinux-pc /usr/lib/nvidia-384/bin $ ls
nvidia-bug-report.sh nvidia-debugdump nvidia-xconfig
nvidia-cuda-mps-control nvidia-persistenced
nvidia-cuda-mps-server nvidia-smi
Edit: When i did “nvidia-bug-report.sh”, i have that:
nvidia-bug-report.sh will now collect information about your
system and create the file ‘nvidia-bug-report.log.gz’ in the current
directory. It may take several seconds to run. In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module. While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.
Please include the ‘nvidia-bug-report.log.gz’ log file when reporting
your bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
Running nvidia-bug-report.sh…ls: impossible d’accéder à ‘/proc/driver/nvidia/./gpus/’: Aucun fichier ou dossier de ce type
If the bug report script hangs after this point consider running with
–safe-mode and --extra-system-data command line arguments.
complete
It saids that its impossible to access to ‘/proc/driver/nvidia/./gpus/’ because there isn’t file or folder of this type…
So run it:
sudo /usr/lib/nvidia-384/bin/nvidia-bug-report.sh
Where did it create the tar.gz file? because when i did “sudo /usr/lib/nvidia-384/bin/nvidia-bug-report.sh” It said that it’s impossible to go into “/proc/driver/nvidia/./gpus/”
In current directory.
It’s an Optimus laptop. You should have the package nvidia-prime installed. You can use
prime-select nvidia
and reboot to switch to nvidia graphics.
prime-select intel
switches back to intel integrated graphics.
Currently you’re switched to intel and the nvidia gpu is off.
But how can i see if i am using my intel card or my nvidia card?
When in go into nvidia-settings I don’t have my card profile.
prime-select query
probably as root.
I think also indicator applets exist.
The problem that i have is when i select the nvidia card with Prime and i restart X, Cinnamon is in safe-mode, so i can’t use the performance of my GTX.
Please run nvidia-bug-report.sh again when switched to nvidia.
Theres’s something really broken in your system install.
Please check/reinstall packages
ubuntu-drivers-common
nvidia-prime
nvidia-graphics-drivers-384
reboot, and post the output of
prime-select query
prime-select nvidia
baboulinux@baboulinux-pc ~ $ dpkg -s ubuntu-drivers-common
Package: ubuntu-drivers-common
Status: install ok installed
Priority: optional
Section: admin
Installed-Size: 238
Maintainer: Ubuntu Developers ubuntu-devel-discuss@lists.ubuntu.com
Architecture: amd64
Version: 1:0.4.17.3
Replaces: jockey-common, jockey-gtk, jockey-kde, nvidia-common (<< 1:0.2.46)
Provides: jockey-common, jockey-gtk, jockey-kde, nvidia-common
Depends: python3:any (>= 3.3.2-2~), debconf (>= 0.5.00) | debconf-2.0, init-system-helpers (>= 1.18~), libc6 (>= 2.4), libdrm2 (>= 2.3.1), libpciaccess0 (>= 0.10.7), pciutils, python3-apt, python3-xkit, udev (>= 204-0ubuntu4~), usbutils, alsa-utils, kmod | module-init-tools
Pre-Depends: dpkg (>= 1.15.7.2)
Suggests: python3-aptdaemon.pkcompat
Breaks: nvidia-prime (<< 0.6)
Conflicts: jockey-common, jockey-gtk, jockey-kde, nvidia-common (<< 1:0.2.46)
Enhances: packagekit-system-interface
Conffiles:
/etc/init/gpu-manager.conf 744bfb477ce6db535862453a1b40c67a
Description: Detect and install additional Ubuntu driver packages
This package aggregates and abstracts Ubuntu specific logic and knowledge
about third-party driver packages. It provides:
- a Python API for detecting driver packages for a particular piece of
hardware or the whole system.
. - an “ubuntu-drivers” command line tool to list or install driver packages
(mostly for integration in installers).
. - a PackageKit plugin for WhatProvides() for types MODALIAS and
HARDWARE_DRIVER, to do the same queries as above through the PackageKit API
(for using in non-distro specific GUIs). This works with aptdaemon’s
PackageKit compatibility layer (python3-aptdaemon.pkcompat) and with
PackageKit’s apt backend, but not with the PackageKit aptcc backend.
. - some NVidia specific support code to find the most appropriate driver
version, as well as setting up the alternatives symlinks that the
proprietary NVidia and FGLRX packages use.
baboulinux@baboulinux-pc ~ $ dpkg -s nvidia-prime
Package: nvidia-prime
Priority: optional
Section: admin
Installed-Size: 66
Maintainer: Alberto Milone alberto.milone@canonical.com
Architecture: amd64
Version: 0.8.2linuxmint1
Replaces: hybrid-graphics
Provides: hybrid-graphics
Depends: mdm | lightdm (>= 1.9.1) | gdm | kdm | sddm, bbswitch-dkms, pciutils, lsb-release, lsb-base (>= 4.1+Debian11ubuntu7)
Breaks: ubuntu-drivers-common (<< 1:0.2.89)
Conflicts: hybrid-graphics
Conffiles:
/etc/init/nvidia-prime.conf 8df768724bf4dbe326d7537b62acf589
Description: Tools to enable NVIDIA’s Prime
This is a set of tools which will enable
NVIDIA’s Prime on MUXless systems.
baboulinux@baboulinux-pc ~ $ dpkg -s nvidia-graphics-drivers-384
dpkg-query: le paquet « nvidia-graphics-drivers-384 » n’est pas installé et aucune information n’est disponible
Utilisez dpkg --info (= dpkg-deb --info) pour examiner les fichiers
archives, et dpkg --contents (= dpkg-deb --contents) pour afficher leur
contenu.
The problem is the graphic driver, it said that is not installed
It’ probably just called nvidia-384
I don’t run mint/ubuntu so I don’t know the exact package names.
When i did that command,
baboulinux@baboulinux-pc ~ $ dpkg -s nvidia-384
I had a really strange answer…
Package: nvidia-384
Priority: optional
Section: restricted/misc
Installed-Size: 303572
Maintainer: Ubuntu Core Developers ubuntu-devel-discuss@lists.ubuntu.com
Architecture: amd64
Source: nvidia-graphics-drivers-384
Version: 384.90-0ubuntu0~gpu16.04.1
Replaces: nvidia-persistenced, nvidia-smi, xorg-driver-binary
Provides: nvidia-driver-binary, nvidia-persistenced, nvidia-smi, xorg-driver-binary, xorg-driver-video
Depends: x11-common (>= 1:7.0.0), make, sed (>> 3.0), dkms, linux-libc-dev, libc6-dev, patch, acpid, lib32gcc1, libc6-i386, passwd, adduser, xserver-xorg-legacy, libc6 (>= 2.2.5), libgl1, libwayland-client0 (>= 1.3.92), libwayland-server0 (>= 1.2.0), libx11-6, libxext6, xorg-video-abi-11 | xorg-video-abi-12 | xorg-video-abi-13 | xorg-video-abi-14 | xorg-video-abi-15 | xorg-video-abi-18 | xorg-video-abi-19 | xorg-video-abi-20 | xorg-video-abi-23, xserver-xorg-core
Recommends: nvidia-settings (>= 331.20), nvidia-prime (>= 0.5) | bumblebee, libcuda1-384, nvidia-opencl-icd-384
Conflicts: nvidia-persistenced, nvidia-smi, xorg-driver-binary
Conffiles:
/etc/modprobe.d/nvidia-384_hybrid.conf 53a3fd011881a1c1da10793c5dd87118
Description: NVIDIA binary driver - version 384.90
The binary driver provide optimized hardware acceleration of OpenGL
applications via a direct-rendering X Server. AGP, PCIe, SLI, TV-out
and flat panel displays are also supported.
This package also includes the source for building the kernel module
required by the Xorg driver, and provides NVIDIA’s implementation of
the Video Decode and presentation API. The latter enables acceleration
for GeForce 8 and later series cards for h264 video.
Release Notes and supported GPUs:
http://www.nvidia.com/object/linux-display-amd64-384.90-driver.html
Modaliases: nvidia_384(pci:v000010DEd000006C0svsdbc03sci, pci:v000010DEd000006C4svsdbc03sci, pci:v000010DEd000006CAsvsdbc03sci, pci:v000010DEd000006CDsvsdbc03sci, pci:v000010DEd000006D1svsdbc03sci, pci:v000010DEd000006D2svsdbc03sci, pci:v000010DEd000006D8svsdbc03sci, pci:v000010DEd000006D9svsdbc03sci, pci:v000010DEd000006DAsvsdbc03sci, pci:v000010DEd000006DCsvsdbc03sci, pci:v000010DEd000006DDsvsdbc03sci, pci:v000010DEd000006DEsvsdbc03sci, pci:v000010DEd000006DFsvsdbc03sci, pci:v000010DEd00000DC0svsdbc03sci, pci:v000010DEd00000DC4svsdbc03sci, pci:v000010DEd00000DC5svsdbc03sci, pci:v000010DEd00000DC6svsdbc03sci, pci:v000010DEd00000DCDsvsdbc03sci, pci:v000010DEd00000DCEsvsdbc03sci, pci:v000010DEd00000DD1svsdbc03sci, pci:v000010DEd00000DD2svsdbc03sci, pci:v000010DEd00000DD3svsdbc03sci, pci:v000010DEd00000DD6svsdbc03sci, pci:v000010DEd00000DD8svsdbc03sci, pci:v000010DEd00000DDAsvsdbc03sci, pci:v000010DEd00000DE0svsdbc03sci, pci:v000010DEd00000DE1svsdbc03sci, pci:v000010DEd00000DE2svsdbc03sci, pci:v000010DEd00000DE3svsdbc03sci, pci:v000010DEd00000DE4svsdbc03sci, pci:v000010DEd00000DE5svsdbc03sci, pci:v000010DEd00000DE7svsdbc03sci, pci:v000010DEd00000DE8svsdbc03sci, pci:v000010DEd00000DE9svsdbc03sci, pci:v000010DEd00000DEAsvsdbc03sci, pci:v000010DEd00000DEBsvsdbc03sci, pci:v000010DEd00000DECsvsdbc03sci, pci:v000010DEd00000DEDsvsdbc03sci, pci:v000010DEd00000DEEsvsdbc03sci, pci:v000010DEd00000DEFsvsdbc03sci, pci:v000010DEd00000DF0svsdbc03sci, pci:v000010DEd00000DF1svsdbc03sci, pci:v000010DEd00000DF2svsdbc03sci, pci:v000010DEd00000DF3svsdbc03sci, pci:v000010DEd00000DF4svsdbc03sci, pci:v000010DEd00000DF5svsdbc03sci, pci:v000010DEd00000DF6svsdbc03sci, pci:v000010DEd00000DF7svsdbc03sci, pci:v000010DEd00000DF8svsdbc03sci, pci:v000010DEd00000DF9svsdbc03sci, pci:v000010DEd00000DFAsvsdbc03sci, pci:v000010DEd00000DFCsvsdbc03sci, pci:v000010DEd00000E22svsdbc03sci, pci:v000010DEd00000E23svsdbc03sci, pci:v000010DEd00000E24svsdbc03sci, pci:v000010DEd00000E30svsdbc03sci, pci:v000010DEd00000E31svsdbc03sci, pci:v000010DEd00000E3Asvsdbc03sci, pci:v000010DEd00000E3Bsvsdbc03sci, pci:v000010DEd00000F00svsdbc03sci, pci:v000010DEd00000F01svsdbc03sci, pci:v000010DEd00000F02svsdbc03sci, pci:v000010DEd00000F03svsdbc03sci, pci:v000010DEd00000FC0svsdbc03sci, pci:v000010DEd00000FC1svsdbc03sci, pci:v000010DEd00000FC2svsdbc03sci, pci:v000010DEd00000FC6svsdbc03sci, pci:v000010DEd00000FC8svsdbc03sci, pci:v000010DEd00000FC9svsdbc03sci, pci:v000010DEd00000FCDsvsdbc03sci, pci:v000010DEd00000FCEsvsdbc03sci, pci:v000010DEd00000FD1svsdbc03sci, pci:v000010DEd00000FD2svsdbc03sci, pci:v000010DEd00000FD3svsdbc03sci, pci:v000010DEd00000FD4svsdbc03sci, pci:v000010DEd00000FD5svsdbc03sci, pci:v000010DEd00000FD8svsdbc03sci, pci:v000010DEd00000FD9svsdbc03sci, pci:v000010DEd00000FDFsvsdbc03sci, pci:v000010DEd00000FE0svsdbc03sci, pci:v000010DEd00000FE1svsdbc03sci, pci:v000010DEd00000FE2svsdbc03sci, pci:v000010DEd00000FE3svsdbc03sci, pci:v000010DEd00000FE4svsdbc03sci, pci:v000010DEd00000FE9svsdbc03sci, pci:v000010DEd00000FEAsvsdbc03sci, pci:v000010DEd00000FECsvsdbc03sci, pci:v000010DEd00000FEDsvsdbc03sci, pci:v000010DEd00000FEEsvsdbc03sci, pci:v000010DEd00000FF3svsdbc03sci, pci:v000010DEd00000FF6svsdbc03sci, pci:v000010DEd00000FF8svsdbc03sci, pci:v000010DEd00000FF9svsdbc03sci, pci:v000010DEd00000FFAsvsdbc03sci, pci:v000010DEd00000FFBsvsdbc03sci, pci:v000010DEd00000FFCsvsdbc03sci, pci:v000010DEd00000FFDsvsdbc03sci, pci:v000010DEd00000FFEsvsdbc03sci, pci:v000010DEd00000FFFsvsdbc03sci, pci:v000010DEd00001001svsdbc03sci, pci:v000010DEd00001004svsdbc03sci, pci:v000010DEd00001005svsdbc03sci, pci:v000010DEd00001007svsdbc03sci, pci:v000010DEd00001008svsdbc03sci, pci:v000010DEd0000100Asvsdbc03sci, pci:v000010DEd0000100Csvsdbc03sci, pci:v000010DEd00001021svsdbc03sci, pci:v000010DEd00001022svsdbc03sci, pci:v000010DEd00001023svsdbc03sci, pci:v000010DEd00001024svsdbc03sci, pci:v000010DEd00001026svsdbc03sci, pci:v000010DEd00001027svsdbc03sci, pci:v000010DEd00001028svsdbc03sci, pci:v000010DEd00001029svsdbc03sci, pci:v000010DEd0000102Asvsdbc03sci, pci:v000010DEd0000102Dsvsdbc03sci, pci:v000010DEd0000103Asvsdbc03sci, pci:v000010DEd0000103Csvsdbc03sci, pci:v000010DEd00001040svsdbc03sci, pci:v000010DEd00001042svsdbc03sci, pci:v000010DEd00001048svsdbc03sci, pci:v000010DEd00001049svsdbc03sci, pci:v000010DEd0000104Asvsdbc03sci, pci:v000010DEd0000104Bsvsdbc03sci, pci:v000010DEd0000104Csvsdbc03sci, pci:v000010DEd00001050svsdbc03sci, pci:v000010DEd00001051svsdbc03sci, pci:v000010DEd00001052svsdbc03sci, pci:v000010DEd00001054svsdbc03sci, pci:v000010DEd00001055svsdbc03sci, pci:v000010DEd00001056svsdbc03sci, pci:v000010DEd00001057svsdbc03sci, pci:v000010DEd00001058svsdbc03sci, pci:v000010DEd00001059svsdbc03sci, pci:v000010DEd0000105Asvsdbc03sci, pci:v000010DEd0000105Bsvsdbc03sci, pci:v000010DEd0000107Csvsdbc03sci, pci:v000010DEd0000107Dsvsdbc03sci, pci:v000010DEd00001080svsdbc03sci, pci:v000010DEd00001081svsdbc03sci, pci:v000010DEd00001082svsdbc03sci, pci:v000010DEd00001084svsdbc03sci, pci:v000010DEd00001086svsdbc03sci, pci:v000010DEd00001087svsdbc03sci, pci:v000010DEd00001088svsdbc03sci, pci:v000010DEd00001089svsdbc03sci, pci:v000010DEd0000108Bsvsdbc03sci, pci:v000010DEd00001091svsdbc03sci, pci:v000010DEd00001094svsdbc03sci, pci:v000010DEd00001096svsdbc03sci, pci:v000010DEd0000109Asvsdbc03sci, pci:v000010DEd0000109Bsvsdbc03sci, pci:v000010DEd00001180svsdbc03sci, pci:v000010DEd00001183svsdbc03sci, pci:v000010DEd00001184svsdbc03sci, pci:v000010DEd00001185svsdbc03sci, pci:v000010DEd00001187svsdbc03sci, pci:v000010DEd00001188svsdbc03sci, pci:v000010DEd00001189svsdbc03sci, pci:v000010DEd0000118Asvsdbc03sci, pci:v000010DEd0000118Esvsdbc03sci, pci:v000010DEd0000118Fsvsdbc03sci, pci:v000010DEd00001193svsdbc03sci, pci:v000010DEd00001194svsdbc03sci, pci:v000010DEd00001195svsdbc03sci, pci:v000010DEd00001198svsdbc03sci, pci:v000010DEd00001199svsdbc03sci, pci:v000010DEd0000119Asvsdbc03sci, pci:v000010DEd0000119Dsvsdbc03sci, pci:v000010DEd0000119Esvsdbc03sci, pci:v000010DEd0000119Fsvsdbc03sci, pci:v000010DEd000011A0svsdbc03sci, pci:v000010DEd000011A1svsdbc03sci, pci:v000010DEd000011A2svsdbc03sci, pci:v000010DEd000011A3svsdbc03sci, pci:v000010DEd000011A7svsdbc03sci, pci:v000010DEd000011B4svsdbc03sci, pci:v000010DEd000011B6svsdbc03sci, pci:v000010DEd000011B7svsdbc03sci, pci:v000010DEd000011B8svsdbc03sci, pci:v000010DEd000011BAsvsdbc03sci, pci:v000010DEd000011BCsvsdbc03sci, pci:v000010DEd000011BDsvsdbc03sci, pci:v000010DEd000011BEsvsdbc03sci, pci:v000010DEd000011C0svsdbc03sci, pci:v000010DEd000011C2svsdbc03sci, pci:v000010DEd000011C3svsdbc03sci, pci:v000010DEd000011C4svsdbc03sci, pci:v000010DEd000011C5svsdbc03sci, pci:v000010DEd000011C6svsdbc03sci, pci:v000010DEd000011C8svsdbc03sci, pci:v000010DEd000011CBsvsdbc03sci, pci:v000010DEd000011E0svsdbc03sci, pci:v000010DEd000011E1svsdbc03sci, pci:v000010DEd000011E2svsdbc03sci, pci:v000010DEd000011E3svsdbc03sci, pci:v000010DEd000011FAsvsdbc03sci, pci:v000010DEd000011FCsvsdbc03sci, pci:v000010DEd00001200svsdbc03sci, pci:v000010DEd00001201svsdbc03sci, pci:v000010DEd00001203svsdbc03sci, pci:v000010DEd00001205svsdbc03sci, pci:v000010DEd00001206svsdbc03sci, pci:v000010DEd00001207svsdbc03sci, pci:v000010DEd00001208svsdbc03sci, pci:v000010DEd00001210svsdbc03sci, pci:v000010DEd00001211svsdbc03sci, pci:v000010DEd00001212svsdbc03sci, pci:v000010DEd00001213svsdbc03sci, pci:v000010DEd00001241svsdbc03sci, pci:v000010DEd00001243svsdbc03sci, pci:v000010DEd00001244svsdbc03sci, pci:v000010DEd00001245svsdbc03sci, pci:v000010DEd00001246svsdbc03sci, pci:v000010DEd00001247svsdbc03sci, pci:v000010DEd00001248svsdbc03sci, pci:v000010DEd00001249svsdbc03sci, pci:v000010DEd0000124Bsvsdbc03sci, pci:v000010DEd0000124Dsvsdbc03sci, pci:v000010DEd00001251svsdbc03sci, pci:v000010DEd00001280svsdbc03sci, pci:v000010DEd00001281svsdbc03sci, pci:v000010DEd00001282svsdbc03sci, pci:v000010DEd00001284svsdbc03sci, pci:v000010DEd00001286svsdbc03sci, pci:v000010DEd00001287svsdbc03sci, pci:v000010DEd00001288svsdbc03sci, pci:v000010DEd00001289svsdbc03sci, pci:v000010DEd0000128Bsvsdbc03sci, pci:v000010DEd00001290svsdbc03sci, pci:v000010DEd00001291svsdbc03sci, pci:v000010DEd00001292svsdbc03sci, pci:v000010DEd00001293svsdbc03sci, pci:v000010DEd00001295svsdbc03sci, pci:v000010DEd00001296svsdbc03sci, pci:v000010DEd00001298svsdbc03sci, pci:v000010DEd00001299svsdbc03sci, pci:v000010DEd0000129Asvsdbc03sci, pci:v000010DEd000012B9svsdbc03sci, pci:v000010DEd000012BAsvsdbc03sci, pci:v000010DEd00001340svsdbc03sci, pci:v000010DEd00001341svsdbc03sci, pci:v000010DEd00001344svsdbc03sci, pci:v000010DEd00001346svsdbc03sci, pci:v000010DEd00001347svsdbc03sci, pci:v000010DEd00001348svsdbc03sci, pci:v000010DEd00001349svsdbc03sci, pci:v000010DEd0000134Bsvsdbc03sci, pci:v000010DEd0000134Dsvsdbc03sci, pci:v000010DEd0000134Esvsdbc03sci, pci:v000010DEd0000134Fsvsdbc03sci, pci:v000010DEd0000137Bsvsdbc03sci, pci:v000010DEd00001380svsdbc03sci, pci:v000010DEd00001381svsdbc03sci, pci:v000010DEd00001382svsdbc03sci, pci:v000010DEd00001390svsdbc03sci, pci:v000010DEd00001391svsdbc03sci, pci:v000010DEd00001392svsdbc03sci, pci:v000010DEd00001393svsdbc03sci, pci:v000010DEd00001398svsdbc03sci, pci:v000010DEd00001399svsdbc03sci, pci:v000010DEd0000139Asvsdbc03sci, pci:v000010DEd0000139Bsvsdbc03sci, pci:v000010DEd0000139Csvsdbc03sci, pci:v000010DEd0000139Dsvsdbc03sci, pci:v000010DEd000013B0svsdbc03sci, pci:v000010DEd000013B1svsdbc03sci, pci:v000010DEd000013B2svsdbc03sci, pci:v000010DEd000013B3svsdbc03sci, pci:v000010DEd000013B4svsdbc03sci, pci:v000010DEd000013B6svsdbc03sci, pci:v000010DEd000013B9svsdbc03sci, pci:v000010DEd000013BAsvsdbc03sci, pci:v000010DEd000013BBsvsdbc03sci, pci:v000010DEd000013BCsvsdbc03sci, pci:v000010DEd000013C0svsdbc03sci, pci:v000010DEd000013C2svsdbc03sci, pci:v000010DEd000013D7svsdbc03sci, pci:v000010DEd000013D8svsdbc03sci, pci:v000010DEd000013D9svsdbc03sci, pci:v000010DEd000013DAsvsdbc03sci, pci:v000010DEd000013F0svsdbc03sci, pci:v000010DEd000013F1svsdbc03sci, pci:v000010DEd000013F2svsdbc03sci, pci:v000010DEd000013F3svsdbc03sci, pci:v000010DEd000013F8svsdbc03sci, pci:v000010DEd000013F9svsdbc03sci, pci:v000010DEd000013FAsvsdbc03sci, pci:v000010DEd000013FBsvsdbc03sci, pci:v000010DEd00001401svsdbc03sci, pci:v000010DEd00001402svsdbc03sci, pci:v000010DEd00001406svsdbc03sci, pci:v000010DEd00001407svsdbc03sci, pci:v000010DEd00001427svsdbc03sci, pci:v000010DEd00001430svsdbc03sci, pci:v000010DEd00001431svsdbc03sci, pci:v000010DEd00001436svsdbc03sci, pci:v000010DEd000015F0svsdbc03sci, pci:v000010DEd000015F7svsdbc03sci, pci:v000010DEd000015F8svsdbc03sci, pci:v000010DEd000015F9svsdbc03sci, pci:v000010DEd00001617svsdbc03sci, pci:v000010DEd00001618svsdbc03sci, pci:v000010DEd00001619svsdbc03sci, pci:v000010DEd0000161Asvsdbc03sci, pci:v000010DEd00001667svsdbc03sci, pci:v000010DEd0000179Csvsdbc03sci, pci:v000010DEd000017C2svsdbc03sci, pci:v000010DEd000017C8svsdbc03sci, pci:v000010DEd000017F0svsdbc03sci, pci:v000010DEd000017F1svsdbc03sci, pci:v000010DEd000017FDsvsdbc03sci, pci:v000010DEd00001B00svsdbc03sci, pci:v000010DEd00001B02svsdbc03sci, pci:v000010DEd00001B06svsdbc03sci, pci:v000010DEd00001B30svsdbc03sci, pci:v000010DEd00001B38svsdbc03sci, pci:v000010DEd00001B80svsdbc03sci, pci:v000010DEd00001B81svsdbc03sci, pci:v000010DEd00001B84svsdbc03sci, pci:v000010DEd00001B87svsdbc03sci, pci:v000010DEd00001BA0svsdbc03sci, pci:v000010DEd00001BA1svsdbc03sci, pci:v000010DEd00001BB0svsdbc03sci, pci:v000010DEd00001BB1svsdbc03sci, pci:v000010DEd00001BB3svsdbc03sci, pci:v000010DEd00001BB4svsdbc03sci, pci:v000010DEd00001BB5svsdbc03sci, pci:v000010DEd00001BB6svsdbc03sci, pci:v000010DEd00001BB7svsdbc03sci, pci:v000010DEd00001BB8svsdbc03sci, pci:v000010DEd00001BE0svsdbc03sci, pci:v000010DEd00001BE1svsdbc03sci, pci:v000010DEd00001C02svsdbc03sci, pci:v000010DEd00001C03svsdbc03sci, pci:v000010DEd00001C07svsdbc03sci, pci:v000010DEd00001C20svsdbc03sci, pci:v000010DEd00001C21svsdbc03sci, pci:v000010DEd00001C22svsdbc03sci, pci:v000010DEd00001C30svsdbc03sci, pci:v000010DEd00001C60svsdbc03sci, pci:v000010DEd00001C61svsdbc03sci, pci:v000010DEd00001C62svsdbc03sci, pci:v000010DEd00001C81svsdbc03sci, pci:v000010DEd00001C82svsdbc03sci, pci:v000010DEd00001C8Csvsdbc03sci, pci:v000010DEd00001C8Dsvsdbc03sci, pci:v000010DEd00001CB1svsdbc03sci, pci:v000010DEd00001CB2svsdbc03sci, pci:v000010DEd00001CB3svsdbc03sci, pci:v000010DEd00001D01svsdbc03sci, pci:v000010DEd00001D10svsdbc03sci, pci:v000010DEd00001D12svsdbc03sci, pci:v000010DEd00000DFCsvsdbc03sci)
It’s installed but why i have a lot of PCI??
Those are just the PCI IDs of supported gpus. Nothing to worry.
Purge/reinstall those packages, reboot, post output of
prime-select query
prime-select nvidia
and /var/log/gpu-manager.log
