• NVIDIA Jetson Nano (Developer Kit Version)
• DeepStream Version 6.0.1
• JetPack Version R32 (release), REVISION: 7.2
• TensorRT Version 8.2.1.8
• Issue Type question
jetsonUtilities (master) $ ./jetsonInfo.py
L4T 32.7.2 [ JetPack UNKNOWN ]
Ubuntu 18.04.6 LTS
Kernel Version: 4.9.253-tegra
CUDA 10.2.300
CUDA Architecture: 5.3
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.2.1.32
TensorRT: 8.2.1.8
Vision Works: 1.6.0.501
VPI: ii libnvvpi1 1.2.3 arm64 NVIDIA Vision Programming Interface library
Vulcan: 1.2.70
I have a rather complex pipeline like:
gst-launch-1.0 v4l2src io-mode=2 do-timestamp=TRUE device=/dev/video1 ! "video/x-raw,width=960,height=540,framerate=20/1" ! nvvidconv ! "video/x-raw(memory:NVMM)" ! mtdmetainject traffic-report-name=bob ! "video/x-raw(memory:NVMM)" ! mtdmetaoverlay qml=/etc/mtdata/qml/simple.qml ! "video/x-raw(memory:NVMM)" ! nvvidconv ! "video/x-raw(memory:NVMM),format=I420" ! queue ! nvvidconv ! video/x-raw ! mtddriversafety detect-drowsiness=false detect-distraction=true driver-location=right distraction-min-speed-kmh=10 distraction-min-calibration-speed-kmh=40 distraction-cal-sec=60 ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12" ! nvv4l2h264enc maxperf-enable=1 ! h264parse config-interval=1 ! capsfilter caps="video/x-h264,stream-format=avc,alignment=au,profile=baseline,mapping=/mtdstream1" ! rtspsink service=8554
which works.
- mtdmetainject just injects some custom meta data into the stream
- mtdmetaoverlay draws some of this meta data on the image
- mtddriversafety is a bin which has 2 nvinfers to do face and facial landmark-detection, and draws these on the image
I would now like to move the mtdmetaoverlay to after the inference (otherwise it gets in the way of the face detection)
so i try :
gst-launch-1.0 v4l2src io-mode=2 do-timestamp=TRUE device=/dev/video1 ! "video/x-raw,width=960,height=540,framerate=20/1" ! mtdmetainject traffic-report-name=bob ! nvvidconv ! "video/x-raw(memory:NVMM),format=I420" ! queue ! nvvidconv ! video/x-raw ! mtddriversafety detect-drowsiness=false detect-distraction=true driver-location=right distraction-min-speed-kmh=10 distraction-min-calibration-speed-kmh=40 distraction-cal-sec=60 ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM)" ! mtdmetaoverlay qml=/etc/mtdata/qml/simple.qml ! "video/x-raw(memory:NVMM)" ! nvvidconv ! "video/x-raw(memory:NVMM),format=I420" ! nvv4l2h264enc maxperf-enable=1 ! h264parse config-interval=1 ! capsfilter caps="video/x-h264,stream-format=avc,alignment=au,profile=baseline,mapping=/mtdstream1" ! rtspsink service=8554
(moved mtdmetaoverlay towards the end) which keeps going inference starts to process (after about 5 seconds) , after which i see:
00:08.299583647 11390 0x55907895e0 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop:<nvinfer-second-10> error: Internal data stream error.
0:00:08.299619221 11390 0x55907895e0 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop:<nvinfer-second-10> error: streaming stopped, reason error (-5)
0:00:08.299684796 11390 0x55907895e0 INFO GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details:<nvinfer-second-10> posting message: Internal data stream error.
0:00:08.299796414 11390 0x55907895e0 INFO GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details:<nvinfer-second-10> posted error message: Internal data stream error.
ERROR: from element /GstPipeline:pipeline0/GstMtdDriverSafety:mtddriversafety0/GstNvInfer:nvinfer-second-10: Internal data stream error.
Additional debug info:
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2288): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstMtdDriverSafety:mtddriversafety0/GstNvInfer:nvinfer-second-10:
Execution ended after 0:00:01.066967747
Setting pipeline to PAUSED ...
0:00:08.300426592 11390 0x558ff5ea00 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<rtspsink0> current READY pending PAUSED, desired next PAUSED
but i don’t have any idea on how to proceed from here. what is this telling me ? It looks like the second nvinfer in the mtddriversafety is triggering this, but in which direction should i look ? Is this a mismatch in the pipeline of caps ? is there any way to get more information. I tried GST_DEBUG=6 gst-launch-1.0 ...., but that killed me with logging and no more of the critical area that i have added above. any help is appreciated.
full log:
full.log (287.1 KB)
