The following is the code:
module Global_Variable
use openacc
implicit none
real*8,parameter :: PI=3.14159265358979d0
!dimensions of the flame, in mm
real*8,parameter :: Lx=120.0d0
real*8,parameter :: Ly=50.0d0
real*8,parameter :: Lz=50.0d0
!discretization of the flame
integer,parameter :: Nx=120 !should be an even #
integer,parameter :: Ny=120 !should be an even #
integer,parameter :: Nz=120 !should be an even #
!integer,parameter :: Nx=10 !should be an even #
!integer,parameter :: Ny=10 !should be an even #
!integer,parameter :: Nz=10 !should be an even #
!integer,parameter :: Nx=60 !should be an even #
!integer,parameter :: Ny=60 !should be an even #
!integer,parameter :: Nz=60 !should be an even #
!increment in x,y,z directions, in microns
real*8,parameter :: dx=Lx/real(Nx,8)
real*8,parameter :: dy=Ly/real(Ny,8)
real*8,parameter :: dz=Lz/real(Nz,8)
integer,parameter :: CCDNX=1024 !# of pixels in the x direction,!should be an even #
integer,parameter :: CCDNY=1024 !# of pixels in the y direction,!should be an even #
real*8,parameter :: CCDpixelSize=0.02d0 !size of each CCD pixel
!real*8,parameter :: Fnumber=8.0d0
integer,parameter :: MaxNofVoxelContri=2000 !maximum # of votex contributes to a CCD pixel
integer,parameter :: TotalNumOfViews=8 !total # of views measured in the exp.
integer,parameter :: NumOfViewsUsed=8 !# of view used
integer,parameter :: NumOfFrame=20 !# of view used
integer,parameter :: SkipOfFrame=1 !# of view used
!real*8,parameter :: noiselevel=0.05d0
real*8,parameter :: Terminallevel=1.0d-2
real*8,parameter :: beta=0.07d0
integer,parameter :: MaxNumPhoton=10000
integer,parameter :: Niteration=50
real*8, allocatable :: CCDWeightList(:,:,:,:) !weight of voxel contribute to a pixel on CCD
real*8, allocatable :: CCDWeightSquare(:,:,:)
integer, allocatable :: CCDNumOfVoxelContri(:,:,:) !# of voxels contribute to a pixel on CCD
integer, allocatable :: CCDVoxelList(:,:,:,:,:) !a list of voxels contribute to a pixel on CCD
real*8 :: Rc(3,3,NumOfViewsUsed)
real*8 :: Tc(3,1,NumOfViewsUsed)
real*8 :: kc(5)
real*8 :: alpha_c
real*8 :: fc(2)
real*8 :: cc(2)
integer :: iframe=0 ! the index of the image also can be named as the ith iframe
real*8 :: CCDTrueData(CCDNX,CCDNY,NumOfViewsUsed)
real*8 :: CCDRecData(CCDNX,CCDNY) !updated for each view
real*8 :: CCDPhotons(CCDNX,CCDNY)
real*8 :: Flame3DMatrixCurr(Nx,Ny,Nz)
real*8 :: Flame3DMatrixTrue(Nx,Ny,Nz)
real*8 :: t1,t2,t3,t4
contains
subroutine initilize(CCDWeightList,CCDWeightSquare,CCDNumOfVoxelContri,CCDVoxelList)
integer :: iviews
integer :: i,j,k
!type(view),allocatable :: views(:)
real*8 :: LocationWord(3,1)
real*8 :: LocationCamera(3,1)
integer :: iphoton
real*8:: rnd(3)
real*8 :: xw,yw,zw,xc,yc,zc,xd1,xd2,xn1,xn2,xp,yp,r_calib_2,dx1_cali,dx2_cali
integer :: maxi,mini,maxk,mink,tempi
integer :: ii,kk
integer :: index1,index2
real*8 :: NumPhoton
real*8 :: rconfusion
real*8:: rsquare,midyu
integer(kind=8) :: random
real*8, allocatable :: temp1(:,:,:,:,:,:), temp2(:,:,:,:,:)
allocate(temp1(NumOfViewsUsed,Nx,Ny,Nz,10,10))
allocate(temp2(NumOfViewsUsed,Nx,Ny,Nz,4))
random=1
!call inputdata() !input CCD data from files
CCDNumOfVoxelContri(:,:,:)=0
do iviews=1,NumOfViewsUsed
!write(*,*) iviews
!CCDNumOfVoxelContri(iviews,:,:)=0
do j=1,Ny
!write(*,*) j
!$acc kernels
do i=1,Nx
!write(*,"('i=',i0)") i
do k=1,Nz
!write(*,"('k=',i0)") k
mini=2*CCDNX;maxi=-2*CCDNX
mink=2*CCDNY;maxk=-2*CCDNY
NumPhoton=0.0d0
CCDPhotons=0.0d0
!$ acc loop
do iphoton=1,MaxNumPhoton
!write(*,"('iphoton=',i0)") iphoton
!call random_number(rnd)
random = random*25214903917 + 11
rnd(1) = mod(random,65536)/real(65536)
rnd(2) = mod(random,65536)/real(65536)
rnd(3) = mod(random,65536)/real(65536)
xw=dx*real(i-30.0d0/(Lx/Nx)-1,8)+0.5d0*dx+dx*(rnd(1)-0.5d0)
yw=dy*real(j+14.0d0/(Ly/Ny)-1,8)+0.5d0*dy+dy*(rnd(2)-0.5d0)
zw=dz*real(k-30.0d0/(Lz/Nz)-1,8)+0.5d0*dz+dz*(rnd(3)-0.5d0)
rsquare=(xw+Tc(1,1,iviews))**2+(yw+Tc(2,1,iviews))**2+(zw+Tc(3,1,iviews))**2
LocationWord(1,1)=xw
LocationWord(2,1)=yw
LocationWord(3,1)=zw
LocationCamera=matmul(Rc(:,:,iviews),LocationWord)+Tc(:,:,iviews)
xc=LocationCamera(1,1)
yc=LocationCamera(2,1)
zc=LocationCamera(3,1)
!ObjectDist=zc
!ImageDist=(fc(1)+fc(2))/2*ObjectDist/(ObjectDist-(fc(1)+fc(2))/2)
!magnification=ImageDist/ObjectDist
xc=(fc(1)+fc(2))*CCDpixelSize/2*xc/(zc-(fc(1)+fc(2))*CCDpixelSize/2)
yc=(fc(1)+fc(2))*CCDpixelSize/2*yc/(zc-(fc(1)+fc(2))*CCDpixelSize/2)
zc=(fc(1)+fc(2))*CCDpixelSize/2*zc/(zc-(fc(1)+fc(2))*CCDpixelSize/2)
!xc=xc*ZZ0*CCDpixelSize
!yc=yc*ZZ0*CCDpixelSize
xn1=xc/zc
xn2=yc/zc
r_calib_2=xn1**2+xn2**2
dx1_cali=2*kc(3)*xn1*xn2+kc(4)*(r_calib_2+2*xn1*xn1)
dx2_cali=kc(3)*(r_calib_2+2*xn2*xn2)+2*kc(4)*xn1*xn2
xd1=(1+kc(1)*r_calib_2+kc(2)*r_calib_2**2+kc(5)*r_calib_2**3)*xn1+dx1_cali
xd2=(1+kc(1)*r_calib_2+kc(2)*r_calib_2**2+kc(5)*r_calib_2**3)*xn2+dx2_cali
xp=fc(1)*(xd1+alpha_c*xd2)+cc(1)
yp=fc(2)*xd2+cc(2)
if(xp>=1 .and. xp<=CCDNX .and. yp>=1 .and. yp<=CCDNY) then
index1=ceiling(xp)
index2=ceiling(yp)
if(mini>index1) mini=index1
if(maxi<index1) maxi=index1
if(mink>index2) mink=index2
if(maxk<index2) maxk=index2
NumPhoton=NumPhoton+1.0d0
CCDPhotons(index1,index2)=CCDPhotons(index1,index2)+1.0d0
end if
end do
CCDPhotons(mini:maxi,mink:maxk)=CCDPhotons(mini:maxi,mink:maxk)/NumPhoton
!write(*,*) 'divide succ'
temp1(iviews,j,i,k,1:maxi-mini+1,1:maxk-mink+1) = CCDPhotons(mini:maxi,mink:maxk)
temp2(iviews,j,i,k,1) = mini
temp2(iviews,j,i,k,2) = maxi
temp2(iviews,j,i,k,3) = mink
temp2(iviews,j,i,k,4) = maxk
CCDPhotons(mini:maxi,mink:maxk)=0.0d0
end do
end do
!$acc end kernels
end do
end do
!write(*,*) iviews
do j=1,Ny
!write(*,*) j
do i=1,Nx
do k=1,Nz
midyu=maxval(CCDPhotons(mini:maxi,mink:maxk))
midyu=minval(CCDPhotons(mini:maxi,mink:maxk))
do ii=temp2(iviews,j,i,k,1),temp2(iviews,j,i,k,2)
!write(*,"('ii=',i0)") ii
do kk=temp2(iviews,j,i,k,3),temp2(iviews,j,i,k,4)
!write(*,"('kk=',i0)") kk
if(temp1(iviews,j,i,k,ii-mini+1,kk-mink+1)>1.0d-4) then
CCDNumOfVoxelContri(iviews,ii,kk)=CCDNumOfVoxelContri(iviews,ii,kk)+1
!write(*,*) 'succ plus 1'
tempi=CCDNumOfVoxelContri(iviews,ii,kk)
!write(*,*) tempi
!write(*,*) CCDPhotons(ii,kk)/rsquare*1.0d8
!write(*,*) CCDWeightList(iviews,ii,kk,tempi)
CCDWeightList(iviews,ii,kk,tempi)=temp1(iviews,j,i,k,ii-mini+1,kk-mink+1)/rsquare*1.0d8
!CCDWeightList(iviews,ii,kk,tempi)= 9
!write(*,*) 'succ to CCDWeightList'
midyu=CCDWeightList(iviews,ii,kk,tempi)
!write(*,*) 'succ to midyu'
CCDVoxelList(iviews,ii,kk,tempi,1)=i
CCDVoxelList(iviews,ii,kk,tempi,2)=j
CCDVoxelList(iviews,ii,kk,tempi,3)=k
end if
end do
end do
end do
end do
end do
end do
end subroutine initilize
end module
program ThreeD_CTC_Sub_Main
use Global_Variable
implicit none
integer (kind=4), dimension(8) :: time=0
call date_and_time(values=time)
write(*, FMT=11) time(1:3), time(5:7)
write(999, FMT=11) time(1:3), time(5:7)
call cpu_time(t1)
allocate(CCDWeightList(NumOfViewsUsed,CCDNX,CCDNY,MaxNofVoxelContri)) !weight of voxel contribute to a pixel on CCD
allocate(CCDWeightSquare(NumOfViewsUsed,CCDNX,CCDNY))
allocate(CCDNumOfVoxelContri(NumOfViewsUsed,CCDNX,CCDNY)) !# of voxels contribute to a pixel on CCD
allocate(CCDVoxelList(NumOfViewsUsed,CCDNX,CCDNY,MaxNofVoxelContri,3)) !a list of voxels contribute to a pixel on CCD
!CCDWeightList(:,:,:,:)=0
!CCDWeightSquare(:,:,:)=0
!CCDVoxelList(:,:,:,:,:)=0
call initilize(CCDWeightList,CCDWeightSquare,CCDNumOfVoxelContri,CCDVoxelList)
deallocate(CCDWeightList)
deallocate(CCDWeightSquare)
deallocate(CCDNumOfVoxelContri)
deallocate(CCDVoxelList)
pause
end program ThreeD_CTC_Sub_Main
