Some problems with the pruned model
• Network Type YOLOv4 Tiny
• TLT Version TAO 5.0
The figure below is the comparison result of yolov4 tiny pruned and pruned before and after retraining.
I use “!tao model yolo_v4_tiny prune -m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/yolov4_cspdarknet_tiny_epoch_$EPOCH.hdf5
-e $SPECS_DIR/yolo_v4_tiny_train_kitti.txt
-o $USER_EXPERIMENT_DIR/experiment_dir_pruned/yolov4_cspdarknet_tiny_pruned.hdf5
-eq intersection
-pth 0.1” to prune the model.
Question1:Why does the retraining pruning model become larger after the pruning model size becomes smaller, so does pruning really reduce the number of parameters?
Question2:The pruned model has no loss in accuracy when QAT is not used, but the accuracy drops a lot after QAT is used. Why?
Please make sure load_graph is set to true when you run training with a pruned model.
From the table you shared, we can see the “retrain pruned QAT model” has no accuracy drop. Also, it is needed to run training if a model is pruned. So, we need to run training against “pruned QAT model”.
Where should I add load_graph?
I try to add yolov4_config in yolo_v4_tiny_retrain_kitti.txt but I get error: message type ‘YOLOv4Config’ has no field named ‘load_graph’.
Is there a detailed description of load_graph that I can read?
I don’t see a description of load_graph.
If a model is pruned, I must to run training?
Sorry, ignore this since you are running yolov4_tiny.
Did you set the pruned model to pruned_model_path ?
To regain accuracy, we recommend retraining the pruned model over the same dataset.
Yes. I’m run the official yolo_v4_tiny.ipynb.
There is not much difference in accuracy and file size. In general, what changes does retraining a pruned model bring?
Can you share the training spec file and full training log?
Sorry, I didn’t save the training log, so I ran again.
yolo_v4_tiny_retrain_kitti.txt (2.3 KB)
retrain_model_log.txt (5.0 MB)
Thanks for the info. I will check further.
That is expected. The hdf5 file or tlt file will still be 68M.
After you run exporting to onnx, the onnx file will be 23M.
yolo_v4_tiny export -m yolov4_cspdarknet_tiny_epoch_xxx.hdf5 -o yolov4_cspdarknet_tiny_epoch_xxx.onnx -e yolo_v4_tiny_retrain_kitti.txt -k nvidia_tlt
