Hi, 3V3 supply should not be always ON. You can find the note in Design Guide as below:
The supply or load switch for the SD Card VDD must be enabled with a GPIO from Jetson. This is required for correct operation after a warm boot. The GPIO used should be selected so VDD is not powered on by default.
Hi,Trumany, thank u for reply,
but I cant find effective way to not powered on 3V3 by default.
Can u help me?
I try to change the gpio state 0 to 1:
gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 3) 1>;
but it doesn’t help.
Do you mean you use GPIO(CC, 3) to enable 3.3V SD supply? I don’t see the enable design in your schematic.
Hi,can someone help me check this problem?
Hi,Trumany,
do you have any suggestions ?
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Hi, kayccc,
We still need your help.Thank u!
please change your hardware design to always on design. Not sure what goes wrong with previous hardware setting.
We will check it, thank you!
