hello, I modified the hardware and powered the vdd of the sd card through gpio, and now it can sdhci3440000 is ok, but when I inserted the sd card, he prompted an error, which caused me to not be able to use the sd card normally
this is dmesg
dmesg.txt (50.4 KB)
hello 984093914,
may I also know which Jetpack release you’re working with?
you may see-also Topic 226010 , it looks an issue with JetPack-5.0.2.
is it customize board?
please see-also Jetson Xavier NX Product Design Guide for [Chapter 10.SD Card and SDIO] for reference,
you may try setting mmc-ocr-mask = <0x3>
did your SD Card design have SDMMC_VDD_EN for enable Card power?
could you please also try to set the vmmc-supply
as battery_reg.
thanks
yes i have it on my own board with SDMMC_VDD_EN but it still happens, i tried to set vmmc-supply = <&hdr40_vdd_3v3>, still doesn’t work, same error
hello 984093914,
please also try configure mmc-ocr-mask
, then the power up voltage depending on board capabilities can be selected.
What is mmc-ocr-mask for, let me try it
hello, i set mmc-ocr-mask=3 , but [ 80.771777] mmc1: CMD CRC or end bit error, int mask 0x40000
please have below modifications,
for tegra194-power-tree-p3668.dtsi
sdhci@3440000{
vmmc-supply = <&p3668_spmic_ldo3>;
vmmc-supply = <&p3668_spmic_sd2>;
and… for tegra194-p3668-common.dtsi
sdhci@3440000{
mmc-ocr-mask = <0x0>;
status = "okay";
JerryChang:
battery_reg
I changed, and then dmesg find
sdhci-tegra 3440000.sdhci: Failed getting OCR mask: 0
hello 984093914,
please refer to kernel driver for power up voltage selections.
for example, kernel_src/kernel/kernel-4.9/drivers/mmc/host/sdhci-tegra.c
static int sdhci_tegra_parse_dt(
if (!of_property_read_u32(np, "mmc-ocr-mask", &val)) {
if (val == 1)
host->ocr_mask &= ~(MMC_VDD_26_27 | MMC_VDD_27_28);
else if (val == 2)
host->ocr_mask &= (MMC_VDD_32_33 | MMC_VDD_165_195);
else if (val == 3)
host->ocr_mask &= (MMC_VDD_33_34 | MMC_VDD_165_195);
I tried to modify the value of mmc-ocr-mask, but it doesn’t work, the function still can’t be realized, when I insert the SD card, it will prompt mmc1: CMD CRC or end bit error, int mask 0x40000
and i find dmesg
[ 3.566337] sd: No Scsi addr parsed to reserve index
Please share your board schematic.
Does this issue happen when you hotplug the card or even connect it since boot would hit this issue?
Also, please check your device tree by converting the dtb back to dts.
You won’t really know what is set in the finalized dtb file by just checking those dtsi files.
hello, this is my boardschematic
Sorry that I am no hardware guy so may not tell it correctly. Is there any GPIO in use to control the VDD_SD_3V3?
I don’t see it in the schematic.
JerryChang:
vmmc-supply
as battery_r
Yes, my baseboard does not have GPIO to control VDD_SD_3V3, I have another baseboard with flying wire and GPIO to control VDD_SD_3V3, I refer to other posts but set it up, but still the same problem,
Please try with this no-gpio board first.
Add nvidia,vmmc-always-on;
You need to give a always-on regulator which is also 3.3v to the vmmc-supply. It cannot be just random dummy regulator.
hello, on this borad,i changed,but it didn’t work, this is the tree
sdhci_sd: sdhci@3440000 {
cd-inverted;
cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Q, 2) 0>;
nvidia,cd-wakeup-capable;
cd-inverted;
vmmc-supply = <&battery_reg>;
status = “okay”;
sdhci@3440000 {
compatible = "nvidia,tegra194-sdhci";
reg = <0x0 0x3440000 0x0 0x20000>;
interrupts = <0x0 0x40 0x4>;
iommus = <0x2 0x18>;
dma-coherent;
max-clk-limit = <0xc65d400>;
bus-width = <0x4>;
cap-mmc-highspeed;
cap-sd-highspeed;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
cd-inverted;
nvidia,min-tap-delay = <0x60>;
nvidia,max-tap-delay = <0x8b>;
nvidia,vqmmc-always-on;
pwrdet-support;
pinctrl-names = "sdmmc_e_33v_enable", "sdmmc_e_33v_disable";
pinctrl-0 = <0x1e>;
pinctrl-1 = <0x1f>;
ignore-pm-notify;
resets = <0x5 0x54>;
reset-names = "sdhci";
pll_source = "pll_p", "pll_c4_muxed";
nvidia,set-parent-clk;
nvidia,parent_clk_list = "pll_p", "pll_p", "pll_p", "pll_p", "pll_p", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "NULL";
clocks = <0x4 0x7a 0x4 0x66 0x4 0xf1 0x4 0xdb>;
clock-names = "sdmmc", "pll_p", "pll_c4_muxed", "sdmmc_legacy_tm";
uhs-mask = <0x8>;
nvidia,en-periodic-calib;
status = "okay";
vmmc-supply = <0x19>;
mmc-ocr-mask = <0x3>;
cd-gpios = <0x13 0x82 0x0>;
linux,phandle = <0xe5>;
phandle = <0xe5>;
prod-settings {
#prod-cells = <0x4>;
prod_c_1_8v {
prod = <0x0 0x1e0 0x7f00000 0x600000>;
prod_c_3_3v {
prod = <0x0 0x1e0 0x7f00000 0x800000>;
prod {
prod = <0x0 0x4 0xfff 0x200 0x0 0x28 0x22 0x2 0x0 0x100 0x1fff004a 0x5090000 0x0 0x128 0x42000000 0x0 0x0 0x1ac 0x4 0x0 0x0 0x1c0 0x1fc0 0x40 0x0 0x1c4 0x3ff77 0x400 0x0 0x1e0 0x8007f000 0x7000 0x0 0x1e4 0x20000000 0x20000000 0x0 0x204 0x80000000 0x0>;
prod_c_ds {
prod = <0x0 0x100 0x1fff0000 0x5090000>;
prod_c_hs {
prod_c_ddr52 {
prod = <0x0 0x3c 0x70000 0x40000 0x0 0x120 0xfffe 0x298>;
prod_c_hs200 {
prod = <0x0 0x3c 0x70000 0x30000 0x0 0x1c0 0xe000 0x4000>;
prod_c_sdr104 {
prod_c_sdr12 {
prod = <0x0 0x3c 0x70000 0x0>;
prod_c_sdr25 {
prod = <0x0 0x3c 0x70000 0x10000>;
prod_c_sdr50 {
prod = <0x0 0x3c 0x70000 0x20000 0x0 0x1c0 0xe000 0x8000>;
tegra194-p3668-all-p3509-0000.dts (224.9 KB)
hello, this my dtsi
