Source for tegrastats and/or info about querying overall GPU utilization?
Hi there,
Is the source code or underlying mechanism used by the tegrastats scrip available somewhere?
We would like to write a tool to programatically monitor/report the overall GPU usage.
We could just “scrape” the output of tegrastats, but it seems like it would be better to read the underlying information directly. Is there a file in /proc (or elsewhere) where the overall GPU utilization can be read from?
GPU load reporting is at /sys/devices/platform/host1x/gpu.0/load
For those looking for other points of data you can get more info by running sudo sh -c “strace ./tegrastats 2>&1 | grep open”
open("/sys/devices/system/cpu/cpu1/online", O_RDONLY) = 3
open("/sys/devices/system/cpu/cpu2/online", O_RDONLY) = 3
open("/sys/devices/system/cpu/cpu0/online", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/kernel/debug/clock/cpu/rate", O_RDONLY) = 3
open("/sys/devices/system/cpu/cpu3/online", O_RDONLY) = 3
open("/proc/stat", O_RDONLY)            = 3
open("/proc/meminfo", O_RDONLY)         = 3
open("/sys/devices/platform/tegra-nvmap/misc/nvmap/heap-generic-0/total_size", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/devices/platform/tegra-nvmap/misc/nvmap/heap-generic-0/free_size", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/devices/platform/tegra-nvmap/misc/nvmap/heap-generic-0/free_max", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/kernel/debug/cpu-tegra/cpu_edp_limit", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 3
open("/sys/devices/virtual/thermal/thermal_zone0/type", O_RDONLY) = 4
open("/sys/devices/virtual/thermal/thermal_zone1/type", O_RDONLY) = 4
open("/sys/devices/virtual/thermal/thermal_zone2/type", O_RDONLY) = 4
open("/sys/devices/virtual/thermal/thermal_zone3/type", O_RDONLY) = 4
open("/sys/devices/virtual/thermal/thermal_zone4/type", O_RDONLY) = 4
open("/sys/devices/virtual/thermal/thermal_zone5/type", O_RDONLY) = 4
open("/sys/devices/virtual/thermal/thermal_zone6/type", O_RDONLY) = 4
open("/sys/devices/virtual/thermal/thermal_zone7/type", O_RDONLY) = 4
open("/proc/iovmminfo", O_RDONLY)       = -1 ENOENT (No such file or directory)
open("/sys/devices/platform/tegra-nvmap/misc/nvmap/heap-iram/total_size", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/devices/platform/tegra-nvmap/misc/nvmap/heap-iram/free_size", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/devices/platform/tegra-nvmap/misc/nvmap/heap-iram/free_max", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/proc/buddyinfo", O_RDONLY)       = 3
open("/dev/gpu_freq_max", O_RDONLY)     = 3
open("/dev/gpu_freq_min", O_RDONLY)     = 3
open("/dev/cpu_freq_max", O_RDONLY)     = 3
open("/dev/cpu_freq_min", O_RDONLY)     = 3
open("/dev/min_online_cpus", O_RDONLY)  = 3
open("/dev/max_online_cpus", O_RDONLY)  = 3
open("/sys/kernel/debug/tegra_denver/nvmstats/instantaneous_stats", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/kernel/debug/clock/emc/rate", O_RDONLY) = 3
open("/sys/kernel/debug/clock/avp.sclk/rate", O_RDONLY) = 3
open("/sys/kernel/debug/clock/vde/rate", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/kernel/debug/clock/3d/rate", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/kernel/debug/clock/gk20a.gbus/rate", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/kernel/debug/clock/gm20b.gbus/rate", O_RDONLY) = 3
open("/sys/kernel/debug/tegra_actmon/emc/avg_activity", O_RDONLY) = 3
open("/sys/kernel/debug/tegra_actmon/avp/avg_activity", O_RDONLY) = 3
open("/sys/kernel/debug/tegra_host/3d_actmon_avg_norm", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/devices/platform/host1x/gk20a.0/load", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/devices/platform/host1x/gpu.0/load", O_RDONLY) = 3
Any info on how to cpu load precentage? Also what are units are gpu.0/load? See numbers above 100 in that field, so don’t understand how to compute a precentage.
Hi richtark,
Introducing from r24.2.1, we added the Tegra Stats Utility section at L4T documentation, you can check the percentage by use tegrastats: [url]https://developer.nvidia.com/embedded/dlc/l4t-documentation-24-2-1[/url]
Here’s the strace output for a Xavier
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
openat(AT_FDCWD, "/tmp/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/tmp/.tstats.txt", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/present", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu6/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu7/cpufreq/cpuinfo_cur_freq", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/gpu_pci/clocks/gpc2clk", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/pci/drivers/nvgpu/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/sys/bus/pci/drivers/nvgpu/module/load", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/kernel/debug/nvmap/iram/size", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/proc/meminfo", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/tegra_denver/nvmstats/instantaneous_stats", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone3/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone3/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone1/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone1/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone6/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone6/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone4/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone4/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone2/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone2/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone0/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone0/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone7/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone7/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone5/temp", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone5/type", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/name", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/rail_name_1", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/in_power1_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/rail_name_2", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/in_power2_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/rail_name_0", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/in_power0_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/name", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/rail_name_1", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/in_power1_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/rail_name_2", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/in_power2_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/rail_name_0", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/in_power0_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/devices/6-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/tmp/.tstats.txt", O_WRONLY|O_CREAT|O_TRUNC, 0666) = 3
openat(AT_FDCWD, "/sys/kernel/debug/bpmp/debug/clk/ape/rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/bpmp/debug/clk/emc/rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/actmon_avg_activity/mc_all", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/bpmp/debug/clk/gpcclk/rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/gpu.0/load", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvenc/clk_enable_count", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvenc1/clk_enable_count", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/bpmp/debug/clk/nvenc/rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/bpmp/debug/clk/nvenc1/rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvdec/clk_enable_count", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvdec1/clk_enable_count", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/bpmp/debug/clk/nvdec/rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/bpmp/debug/clk/nvdec1/rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/in_power0_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/in_power1_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/iio_device/in_power2_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/in_power0_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/in_power1_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/iio_device/in_power2_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone3/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone1/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone6/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone4/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone2/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone0/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone7/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone5/temp", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/online", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/online", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/online", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/online", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/online", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/online", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu6/online", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/devices/system/cpu/cpu7/online", O_RDONLY) = 3
openat(AT_FDCWD, "/proc/stat", O_RDONLY) = 3
openat(AT_FDCWD, "/proc/buddyinfo", O_RDONLY) = 3
I have the same question. How we can calculate CPU usage per cores?
In this link there was the equation to calculate that in general..
https://www.eukhost.com/forums/forum/general/technology-forum/22321-what-is-cpu-utilization-and-how-can-it-be-calculated
But in L4T or more specific on Jetson TX2 which file and which params are needed? Appreciate for any guide to this. Milad
Here is my strace for tegrastat
strace tegrastats 2>&1 | grep open        openat(AT_FDCWD, "/usr/local/cuda-10.2/lib64/tls/aarch64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/local/cuda-10.2/lib64/tls/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/local/cuda-10.2/lib64/aarch64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/local/cuda-10.2/lib64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/include/tls/aarch64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/include/tls/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/include/aarch64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/include/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "tls/aarch64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "tls/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "aarch64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3        openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3        openat(AT_FDCWD, "/usr/local/cuda-10.2/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/usr/include/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "tls/aarch64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "tls/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "aarch64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3        openat(AT_FDCWD, "/tmp/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/emc/rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/kernel/actmon_avg_activity/mc_all", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/class/devfreq/18000000.vgpu/cur_freq", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/kernel/tegra_gpu/gpu_rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/gpcclk/rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/devices/17000000.gp10b/load", O_RDONLY) = 3        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvenc/state", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvenc1/state", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvenc/rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvenc1/rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvdec/state", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvdec1/state", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvdec/rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvdec1/rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvjpg/state", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/dev/nvbpmpdebugfs/bpmp_debug/clk/nvjpg/rate", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/devices/system/cpu/present", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq", O_RDONLY) = -1 EACCES (Permission denied)        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_cur_freq", O_RDONLY) = -1 EACCES (Permission denied)        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/cpufreq/cpuinfo_cur_freq", O_RDONLY) = -1 EACCES (Permission denied)        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/cpufreq/cpuinfo_cur_freq", O_RDONLY) = -1 EACCES (Permission denied)        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/cpufreq/cpuinfo_cur_freq", O_RDONLY) = -1 EACCES (Permission denied)        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/cpufreq/cpuinfo_cur_freq", O_RDONLY) = -1 EACCES (Permission denied)        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/pci/drivers/nvgpu/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3        openat(AT_FDCWD, "/sys/bus/pci/drivers/nvgpu/module/load", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/proc/meminfo", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone3/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone3/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone1/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone1/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone6/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone6/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone4/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone4/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone2/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone2/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone0/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone0/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone7/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone7/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone5/temp", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone5/type", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/name", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/rail_name_1", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power1_input", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/rail_name_2", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power2_input", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/rail_name_0", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power0_input", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/name", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/rail_name_1", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power1_input", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/rail_name_2", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power2_input", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/rail_name_0", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power0_input", O_RDONLY) = 4        openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/bus/i2c/devices/1-0041/name", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/bus/i2c/devices/6-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/bus/i2c/devices/7-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)        openat(AT_FDCWD, "/sys/kernel/actmon_avg_activity/mc_all", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/17000000.gp10b/load", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power0_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power1_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power2_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power0_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power1_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power2_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone3/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone1/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone6/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone4/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone2/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone0/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone7/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone5/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/online", O_RDONLY) = 3        openat(AT_FDCWD, "/proc/stat", O_RDONLY) = 3        openat(AT_FDCWD, "/proc/meminfo", O_RDONLY) = 3        openat(AT_FDCWD, "/proc/buddyinfo", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/kernel/actmon_avg_activity/mc_all", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/17000000.gp10b/load", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/cpufreq/scaling_cur_freq", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power0_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power1_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0040/iio_device/in_power2_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power0_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power1_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/bus/i2c/devices/0-0041/iio_device/in_power2_input", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone3/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone1/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone6/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone4/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone2/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone0/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone7/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/virtual/thermal/thermal_zone5/temp", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu0/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu1/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu2/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu3/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu4/online", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/system/cpu/cpu5/online", O_RDONLY) = 3        openat(AT_FDCWD, "/proc/stat", O_RDONLY) = 3        openat(AT_FDCWD, "/proc/meminfo", O_RDONLY) = 3        openat(AT_FDCWD, "/proc/buddyinfo", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/kernel/actmon_avg_activity/mc_all", O_RDONLY) = 3        openat(AT_FDCWD, "/sys/devices/17000000.gp10b/load", O_RDONLY) = 3 ```
I found a way from this link
that use /proc/stat and calculate per core usage.
But I’m not sure that is the best way, or tegrastat uses this way. Because it compares pervious state and current state of core usages. So you have to store last stat… Somehow lame in contrast with gpu usage that u can simply read gpu.0/load file
Output for jetson nano
openat(AT_FDCWD, "/sys/kernel/debug/nvmap/iram/size", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/nvmap/iram/clients", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/0-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/0-0041/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/1-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/1-0041/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/name", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/rail_name_1", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_power1_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/rail_name_2", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_power2_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/rail_name_0", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_power0_input", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device1/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device2/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device3/", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/7-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/2-0040/name", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/kernel/debug/clk/ape/clk_rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/emc/clk_rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/gpcclk/clk_rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvenc/clk_rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvdec/clk_rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvjpg/clk_enable_count", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/nvjpg/clk_rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/clk/vic03/clk_rate", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/kernel/debug/vic/actmon_avg_norm", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_power0_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_power1_input", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_power2_input", O_RDONLY) = 3
