source_sync.sh with tegra-l4t-r32.7.2 tag fails because tegra-l4t-r32.7.2 tag does not exist.
Couldn’t find tag tegra-l4t-r32.7.2
It does not exist below.
https://nv-tegra.nvidia.com/r/admin/repos/linux-4.9,tags
./source_sync.sh -t tegra-l4t-r32.7.2
Downloading default kernel/kernel-4.9 source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/kernel/kernel-4.9'...
The default kernel/kernel-4.9 source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/kernel/kernel-4.9
Couldn't find tag tegra-l4t-r32.7.2
/builds/l4t_test/work/Linux_for_Tegra/sources/kernel/kernel-4.9 source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default kernel/nvgpu source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/kernel/nvgpu'...
The default kernel/nvgpu source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/kernel/nvgpu
/builds/l4t_test/work/Linux_for_Tegra/sources/kernel/nvgpu source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default kernel/nvidia source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/kernel/nvidia'...
The default kernel/nvidia source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/kernel/nvidia
/builds/l4t_test/work/Linux_for_Tegra/sources/kernel/nvidia source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/soc/t18x source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t18x'...
The default hardware/nvidia/soc/t18x source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t18x
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t18x source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/tegra/common source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common'...
The default hardware/nvidia/platform/tegra/common source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t18x/common source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common'...
The default hardware/nvidia/platform/t18x/common source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t18x/quill source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/quill'...
The default hardware/nvidia/platform/t18x/quill source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/quill
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/quill source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t18x/lanai source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/lanai'...
The default hardware/nvidia/platform/t18x/lanai source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/lanai
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/lanai source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/soc/t210 source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t210'...
The default hardware/nvidia/soc/t210 source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t210
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t210 source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t210/common source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/common'...
The default hardware/nvidia/platform/t210/common source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/common
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/common source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t210/jetson source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/jetson'...
The default hardware/nvidia/platform/t210/jetson source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/jetson
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/jetson source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t210/porg source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg'...
The default hardware/nvidia/platform/t210/porg source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t210/batuu/kernel-dts source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/batuu/kernel-dts'...
The default hardware/nvidia/platform/t210/batuu/kernel-dts source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/batuu/kernel-dts
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/batuu/kernel-dts source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/soc/t19x source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x'...
The default hardware/nvidia/soc/t19x source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t19x/common source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common'...
The default hardware/nvidia/platform/t19x/common source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t19x/galen/kernel-dts source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts'...
The default hardware/nvidia/platform/t19x/galen/kernel-dts source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t19x/jakku/kernel-dts source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts'...
The default hardware/nvidia/platform/t19x/jakku/kernel-dts source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t19x/mccoy/kernel-dts source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/mccoy/kernel-dts'...
The default hardware/nvidia/platform/t19x/mccoy/kernel-dts source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/mccoy/kernel-dts
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/mccoy/kernel-dts source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/platform/t19x/galen-industrial/kernel-dts source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen-industrial/kernel-dts'...
The default hardware/nvidia/platform/t19x/galen-industrial/kernel-dts source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen-industrial/kernel-dts
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen-industrial/kernel-dts source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default hardware/nvidia/soc/tegra source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra'...
The default hardware/nvidia/soc/tegra source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra
/builds/l4t_test/work/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra source sync to tag tegra-l4t-r32.7.2 failed!
Downloading default u-boot source...
Cloning into '/builds/l4t_test/work/Linux_for_Tegra/sources/u-boot'...
The default u-boot source is downloaded in: /builds/l4t_test/work/Linux_for_Tegra/sources/u-boot
/builds/l4t_test/work/Linux_for_Tegra/sources/u-boot source sync to tag tegra-l4t-r32.7.2 failed!
Please create a tag for tegra-l4t-r32.7.2.
Best regards,
