it seems that the git tags are missing for the L4T 32.2.3 release in the kernel source repos. Is it safe to use the sources tagged with tegra-l4t-r32.2.2 with the L4T 32.2.3 driver package?
hello MarkusHeß,
thanks for reporting the failure. I also cannot find tag tegra-l4t-r32.2.3 for syncing the sources.
you may replace the kernel sources by L4T 32.2.3 driver package to built the image as temporary solution.
BTW, you may also check r32.2.3 release notes for the details of release information.
thanks
Hi JerryChang,
the release tag name mentioned in the release notes is tegra-l4t-r32.2.3. Unfortunately, using the kernel from the driver package is not possible because we use a custom carrier board and have to make some changes to the kernel and device tree.
Ok, I resynced and found that there is now a git tag named “tegra-l4t-r32.2.3-1”. Thanks for fixing this issue!
