Hello all!
I am developing a ray caster where I have to calculate a triple matrix multiply for every frame, my equation is of the form:
R = M T N
M typically has a size of (768 x d), T is (d x d) and N is (d x 768). d is the degree of the surface, so it is usually below 10. (To be more precise T is a tensor of size (d x d x d), so T is stored as a tiled float4 texture where I pull 4 components at a time into shared memory.)
My current implementation (at the bottom of this message) is based on the example from the 0.8 programming guide (chapter 7). I first form the necessary sub block(s) of T N, then I pull in the necessary block(s) of M and calculate R. As far as I understand, the programming guide is written to be educational, and not a high-performance implementation. So I was wondering if anyone could shed some light on possible optimizations for doing several matrix multiplies in one go one the GPU?
// These textures are matrices whith size m*t, t*t and t*n respectively
texture<float, 2, cudaReadModeElementType> M;
texture<float, 2, cudaReadModeElementType> N;
texture<float4, 2, cudaReadModeElementType> T;
__device__
void TriMatMul( float *res, const int inner_blocks,
const int t, const int tile ) {
// Block index
const int bx = blockIdx.x;
const int by = blockIdx.y;
// Thread index
const int tx = threadIdx.x;
const int ty = threadIdx.y;
float4 Csub = make_float4( 0.0, 0.0, 0.0, 0.0 );
for( int j = 0; j < inner_blocks; ++j ) {
// We allocate shared memory for one float block and one float4 block.
// First we use them to read in values from T and N
// and calculate one element of W. When we have all the elements,
// read from M into Ms and store the values we calculated in Ws.
// This reduces the amount of shared memory we need to allocate.
__shared__ float4 Ws[BLOCK_SIZE][BLOCK_SIZE];
__shared__ float Ms[BLOCK_SIZE][BLOCK_SIZE];
// First we build the W = TN^T matrix
float4 Wsub = make_float4( 0.0, 0.0, 0.0, 0.0 );
for( int i = 0; i < inner_blocks; ++i ) {
// Load the matrices from texture memory to shared memory.
// Each thread loads one element of each matrix Notice
// that we offset the access to Ts by tile. T is
// orignally filled with zeros, so reading extra elements
// should not be a problem.
Ws[ty][tx] = texfetch( T, tx + i*blockDim.x, ty + j*blockDim.y +
tile*t);
Ms[ty][tx] = texfetch( N, tx + bx*blockDim.x, ty + i*blockDim.y);
__syncthreads();
// The blocksize will seldom match the dimensions of the
// matrices, so we have to avoid summing the invalid
// elements.
const int kend = min( blockDim.x, t - i*blockDim.x );
for ( int k = 0; k < kend; ++k ) {
Wsub.x += Ws[ty][k].x * Ms[k][tx];
Wsub.y += Ws[ty][k].y * Ms[k][tx];
Wsub.z += Ws[ty][k].z * Ms[k][tx];
Wsub.w += Ws[ty][k].w * Ms[k][tx];
__syncthreads();
// Write the element into Ws
Ws[ty][tx] = Wsub;
// Then each thread loads one element from the M matrix.
Ms[ty][tx] = texfetch( M, tx + j*blockDim.x, ty + by*blockDim.y );
// This syncthreads ensures both that Ws is fully calculated,
// and that Ms has been filled from global memory.
__syncthreads();
const uint kend = min( blockDim.x, t - j*blockDim.x );
Csub.x += Ms[ty][k] * Ws[k][tx].x;
Csub.y += Ms[ty][k] * Ws[k][tx].y;
Csub.z += Ms[ty][k] * Ws[k][tx].z;
Csub.w += Ms[ty][k] * Ws[k][tx].w;
__syncthreads(); // Sync before we read more into Ms and Ws
// Write out the result. Res is of size maxsize, so it should not
// be a problem to write out of bounds here.
res[tile*4 + 0] = Csub.x;
res[tile*4 + 1] = Csub.y;
res[tile*4 + 2] = Csub.z;
res[tile*4 + 3] = Csub.w;
