Have sporadic segfaults of X.Org server since I did install nvidia 352.30 driver. Allways loos all work!
What to do??
Log: ( Xorg.0.log.old)
[ 78929.336] (EE)
[ 78929.337] (EE) Backtrace:
[ 78929.345] (EE) 0: /usr/bin/X (xorg_backtrace+0x48) [0x7fe387a3d848]
[ 78929.345] (EE) 1: /usr/bin/X (0x7fe387894000+0x1ad539) [0x7fe387a41539]
[ 78929.345] (EE) 2: /lib/x86_64-linux-gnu/libpthread.so.0 (0x7fe386990000+0x10340) [0x7fe3869a0340]
[ 78929.345] (EE) 3: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x5482a6) [0x7fe37f81a2a6]
[ 78929.345] (EE) 4: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x526859) [0x7fe37f7f8859]
[ 78929.345] (EE) 5: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x15e842) [0x7fe37f430842]
[ 78929.345] (EE) 6: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x1627c7) [0x7fe37f4347c7]
[ 78929.345] (EE) 7: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x160dbe) [0x7fe37f432dbe]
[ 78929.345] (EE) 8: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x159562) [0x7fe37f42b562]
[ 78929.345] (EE) 9: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x161642) [0x7fe37f433642]
[ 78929.345] (EE) 10: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x16438b) [0x7fe37f43638b]
[ 78929.345] (EE) 11: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x13dc22) [0x7fe37f40fc22]
[ 78929.345] (EE) 12: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7fe37f2d2000+0x514f43) [0x7fe37f7e6f43]
[ 78929.345] (EE) 13: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so (0x7fe382a03000+0x6f746b) [0x7fe3830fa46b]
[ 78929.345] (EE)
[ 78929.345] (EE) Segmentation fault at address 0x0
[ 78929.345] (EE)
Fatal server error:
[ 78929.346] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 78929.346] (EE)
[ 78929.346] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 78929.346] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 78929.346] (EE)
[ 78932.532] (EE) Server terminated with error (1). Closing log file.
Post-mortem backtrace:
(sudo gdb /usr/bin/Xorg /etc/X11/core, “backtrace full”)
GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type “show copying”
and “show warranty” for details.
This GDB was configured as “x86_64-linux-gnu”.
Type “show configuration” for configuration details.
For bug reporting instructions, please see:
http://www.gnu.org/software/gdb/bugs/.
Find the GDB manual and other documentation resources online at:
http://www.gnu.org/software/gdb/documentation/.
For help, type “help”.
Type “apropos word” to search for commands related to “word”…
Reading symbols from /usr/bin/Xorg…(no debugging symbols found)…done.
[New LWP 1896]
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib/x86_64-linux-gnu/libthread_db.so.1”.
warning: the debug information found in “/lib64/ld-2.19.so” does not match “/lib64/ld-linux-x86-64.so.2” (CRC mismatch).
Core was generated by `/usr/bin/X -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt’.
Program terminated with signal SIGABRT, Aborted.
#0 0x00007fe3853e4cc9 in __GI_raise (sig=sig@entry=6)
at …/nptl/sysdeps/unix/sysv/linux/raise.c:56
56 …/nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) backtrace full
resultvar = 0
pid = 1896
selftid = 1896
#1 0x00007fe3853e80d8 in __GI_abort () at abort.c:89
save_stage = 2
act = {__sigaction_handler = {sa_handler = 0x0, sa_sigaction = 0x0},
sa_mask = {__val = {140615392986872, 140726769824312,
140615206036823, 1, 0, 0, 140615169559848, 1, 140726769824312,
140615221214192, 140615206065429, 0, 140615169757072,
140615212682944, 140726769824096, 0}}, sa_flags = -2008230416,
sa_restorer = 0x7fe387c6e9c0}
sigs = {__val = {32, 0 <repeats 15 times>}}
#2 0x00007fe387a4398e in OsAbort ()
No symbol table info available.
#3 0x00007fe387929cc7 in ddxGiveUp ()
#4 0x00007fe387a48e22 in ?? ()
#5 0x00007fe387a49b28 in FatalError ()
#6 0x00007fe387a4158c in ?? ()
—Type to continue, or q to quit—
#7
No locals.
#8 0x00007fe37f81a2a6 in ?? ()
from /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
#9 0x00007fe37f7f8859 in ?? ()
#10 0x00007fe37f430842 in ?? ()
#11 0x00007fe37f4347c7 in ?? ()
#12 0x00007fe37f432dbe in ?? ()
#13 0x00007fe37f42b562 in ?? ()
#14 0x00007fe37f433642 in ?? ()
#15 0x00007fe37f43638b in ?? ()
#16 0x00007fe37f40fc22 in ?? ()
#17 0x00007fe37f7e6f43 in ?? ()
#18 0x00007fe3830fa46b in ?? ()
from /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
#19 0x00007fe382f0d1a7 in ?? ()
#20 0x00007fe382f0dce8 in ?? ()
#21 0x00007fe3830ff9a5 in ?? ()
#22 0x00007fe38141ab2f in ?? ()
from /usr/lib/nvidia-352/libnvidia-glcore.so.352.30
#23 0x00007fe382f0ad44 in ?? ()
#24 0x00007fe3830fab7d in ?? ()
#25 0x00007fe38141c911 in ?? ()
#26 0x00007fe381423925 in ?? ()
#27 0x00007fe3830fd49b in ?? ()
#28 0x00007fe3830f9456 in ?? ()
#29 0x00007fe3830fc637 in ?? ()
#30 0x00007fe3878e9f0e in ?? ()
#31 0x00007fe3878edd9a in ?? ()
#32 0x00007fe3853cfec5 in __libc_start_main (main=0x7fe3878d91c0, argc=11,
argv=0x7ffd812051e8, init=, fini=,
rtld_fini=, stack_end=0x7ffd812051d8) at libc-start.c:287
result =
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {0, -5436521856894394212,
140615208505797, 140726769832416, 0, 0, 5437703390623277212,
5425309595676680348}, mask_was_saved = 0}}, priv = {pad = {
0x0, 0x0, 0x7fe387a4d4a0 <__libc_csu_init>, 0x7ffd812051e8},
data = {prev = 0x0, cleanup = 0x0, canceltype = -2019240800}}}
not_first_call =
#33 0x00007fe3878d91ee in _start ()
(gdb)
(gdb)
(gdb)
nvidia-bug-report.log.gz (187 KB)
