Ssd_Mobilenet_V2 on Deepstream-app Aborted (core dumped)
I trained ssd_mobilenet_v2 and converted to uff successfully. I tested using the inference instructions in https://devtalk.nvidia.com/default/topic/1050377/jetson-nano/deep-learning-inference-benchmarking-instructions/ and it ran properly. I also tested on https://github.com/AastaNV/TRT_object_detection with no problems. However while running it using the deepstream-app this was the error.
sharan@jetson-nano:~/deepstream_sdk_v4.0.1_jetson/sources/objectDetector_SSD$ deepstream-app -c deepstream_app_config_ssd.txt
Using winsys: x11
0:00:01.397554664 26563     0x1657e4d0 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:useEngineFile(): Failed to read from model engine file
0:00:01.397651333 26563     0x1657e4d0 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
deepstream-app: nvdsiplugin_ssd.cpp:53: FlattenConcat::FlattenConcat(int, bool): Assertion `mConcatAxisID == 1 || mConcatAxisID == 2 || mConcatAxisID == 3' failed.
The default configure in objectDetector_SSD is for model ssd_inception_v2_coco.
Please check this comment for the change of ssd_mobilenet_v2:
https://devtalk.nvidia.com/default/topic/1066088/deepstream-sdk/how-to-use-ssd_mobilenet_v2/post/5399649/#5399649
Yes. I changed it for mobilenet. The default coco trained SSD-Mobilenetv2 seems to run fine. This error occurs only when I use a custom trained SSD-Mobilenetv2 detector.
The problem seems to be with the nvdsiplugin_ssd.cpp FlattenConcat part. But since I am able to run it without deepstream I assume there is no problem with the weights conversion part. So is the deepstream version(4.0.1) a problem? What else could be the reason?
Do you mean the model can be inferenced with TensorRT but meet the #1 error with Deepstream?
If yes, could you share the model with us so we can check it further.
Yes. The model can be inferenced using tensorrt. The error arises only when using deepstream.
Sent the model files in private message. Please do the necessary.
It looks like your class number is 2, is it correct?
Except from the class number, do you have any customized item for your model?
Hi, the class number is 1 only. Other than that I didnt modify any parameters during training.
We are checking this issue. Will update more information with you asap.
Thanks for your patience.
We can run your model with the following change. Please give it a try.
1. Convert .pb file into .uff with following config.py
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node("Input",
    op="Placeholder",
    dtype=tf.float32,
    shape=[1, 3, 300, 300])
PriorBox = gs.create_plugin_node(name="GridAnchor", op="GridAnchor_TRT",
    numLayers=6,
    minSize=0.2,
    maxSize=0.95,
    aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
    variance=[0.1,0.1,0.2,0.2],
    featureMapShapes=[19, 10, 5, 3, 2, 1])
NMS = gs.create_plugin_node(name="NMS", op="NMS_TRT",
    shareLocation=1,
    varianceEncodedInTarget=0,
    backgroundLabelId=0,
    confidenceThreshold=1e-8,
    nmsThreshold=0.6,
    topK=100,
    keepTopK=100,
    numClasses=2,
    inputOrder=[0, 2, 1],
    confSigmoid=1,
    isNormalized=1,
    scoreConverter="SIGMOID")
concat_priorbox = gs.create_node(name="concat_priorbox", op="ConcatV2", dtype=tf.float32, axis=2)
concat_box_loc = gs.create_plugin_node("concat_box_loc", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
concat_box_conf = gs.create_plugin_node("concat_box_conf", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
namespace_plugin_map = {
    "MultipleGridAnchorGenerator": PriorBox,
    "Postprocessor": NMS,
    "Preprocessor": Input,
    "ToFloat": Input,
    "image_tensor": Input,
    "Concatenate": concat_priorbox,
    "concat": concat_box_loc,
    "concat_1": concat_box_conf
def preprocess(dynamic_graph):
    # Now create a new graph by collapsing namespaces
    dynamic_graph.collapse_namespaces(namespace_plugin_map)
    # Remove the outputs, so we just have a single output node (NMS).
    dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
    dynamic_graph.find_nodes_by_op("NMS_TRT")[0].input.remove("Input")
2. Apply following change in /opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_SSD
diff --git a/sources/objectDetector_SSD/config_infer_primary_ssd.txt b/sources/objectDetector_SSD/config_infer_primary_ssd.txt
index bafdff7..089ac89 100755
--- a/sources/objectDetector_SSD/config_infer_primary_ssd.txt
+++ b/sources/objectDetector_SSD/config_infer_primary_ssd.txt
@@ -64,13 +64,13 @@ offsets=127.5;127.5;127.5
 model-color-format=0
 model-engine-file=sample_ssd_relu6.uff_b1_fp32.engine
 labelfile-path=ssd_coco_labels.txt
-uff-file=sample_ssd_relu6.uff
+uff-file=///home/nvidia/topic_1067003/topic_1067003.uff
 uff-input-dims=3;300;300;0
 uff-input-blob-name=Input
 batch-size=1
 ## 0=FP32, 1=INT8, 2=FP16 mode
 network-mode=0
-num-detected-classes=91
+num-detected-classes=2
 interval=0
 gie-unique-id=1
 is-classifier=0
3. Run
$ cd /opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_SSD
$ cp /usr/src/tensorrt/data/ssd/ssd_coco_labels.txt .
$ export CUDA_VER=10.0
$ make -C nvdsinfer_custom_impl_ssd
Thanks and please let us know your result.
