Can I connect an SDD disk as the NX?
If your carrier board has a SATA port then you can, but the developer kit NX does not have a SATA port. A USB external SSD could be used, or an M.2 if single sided (there isn’t enough physical room for double sided) could be used on the dev kit if you just want extra storage.
please refer to
