Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 20106856
Date: Sun Nov 29 10:38:30 GMT 2015
uname: Linux StewartPC 4.2.5-1-ARCH #1 SMP PREEMPT Tue Oct 27 08:13:28 CET 2015 x86_64 GNU/Linux
command line flags:
[stewartlittle@StewartPC ~]$ steam --logverbose 6
Running Steam on arch rolling 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1447125378)
(steam:2386): Gtk-WARNING **: Unable to locate theme engine in module_path: “adwaita”,
/usr/share/themes/Adwaita/gtk-2.0/gtkrc:1163: error: unexpected identifier direction', expected character }’
Fontconfig error: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 70: non-double matrix element
Fontconfig warning: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 78: saw unknown, expected number
[1129/104301:ERROR:main_delegate.cc(751)] Could not load cef_extensions.pak
[1129/104301:ERROR:browser_main_loop.cc(189)] Running without the SUID sandbox! See chromium - An open-source project to help move the web forward. - Monorail for more information on developing with the sandbox on.
Installing breakpad exception handler for appid(steamwebhelper)/version(20151109182310)
Installing breakpad exception handler for appid(steamwebhelper)/version(1447093390)
Installing breakpad exception handler for appid(steamwebhelper)/version(1447125378)
Wireless receiver firmware /home/stewartlittle/.local/share/Steam/ubuntu12_32/…/controller_base/d0ggle.bin loaded, version 1442256398.
FillInMachineIDInfo took a total of 0 milliseconds
Generating new string page texture 7: 128x256, total string texture memory is 131.07 KB
Generating new string page texture 8: 64x256, total string texture memory is 196.61 KB
Generating new string page texture 9: 48x256, total string texture memory is 245.76 KB
Generating new string page texture 10: 256x256, total string texture memory is 507.90 KB
Generating new string page texture 11: 8x256, total string texture memory is 516.10 KB
Generating new string page texture 12: 16x256, total string texture memory is 532.48 KB
Generating new string page texture 13: 24x256, total string texture memory is 557.06 KB
Generating new string page texture 14: 32x256, total string texture memory is 589.82 KB
roaming config store loaded successfully - 4183 bytes.
migrating temporary roaming config store
Failed to init SteamVR because it isn’t installed
ExecCommandLine: “”/home/stewartlittle/.local/share/Steam/ubuntu12_32/steam" “–logverbose” “6” "
System startup time: 17.50 seconds
STEAM_RUNTIME has been set by the user to: /home/stewartlittle/.local/share/Steam/ubuntu12_32/steam-runtime
[1129/104319:ERROR:renderer_main.cc(200)] Running without renderer sandbox
Generating new string page texture 83: 1024x256, total string texture memory is 1.64 MB
Generating new string page texture 84: 128x256, total string texture memory is 131.07 KB
Generating new string page texture 85: 128x256, total string texture memory is 1.77 MB
ExecCommandLine: “/home/stewartlittle/.steam/root/ubuntu12_32/steam steam://open/driverhelperready”
ExecSteamURL: “steam://open/driverhelperready”
(steam:2386): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn’t believe we’re it’s parent.
Generating new string page texture 92: 128x256, total string texture memory is 1.90 MB
Generating new string page texture 94: 256x256, total string texture memory is 2.16 MB
Generating new string page texture 123: 128x256, total string texture memory is 2.29 MB
[1129/104325:ERROR:renderer_main.cc(200)] Running without renderer sandbox
Generating new string page texture 126: 256x256, total string texture memory is 2.56 MB
Generating new string page texture 129: 384x256, total string texture memory is 2.95 MB
assert_20151129104300_1.dmp[2565]: Uploading dump (out-of-process)
/tmp/dumps/assert_20151129104300_1.dmp
/home/stewartlittle/.local/share/Steam/steam.sh: line 756: 2386 Segmentation fault (core dumped) $STEAM_DEBUGGER “$STEAMROOT/$STEAMEXEPATH” “$@”
[1129/104341:WARNING:pref_notifier_impl.cc(27)] pref observer found at shutdown plugins.always_authorize
[1129/104341:WARNING:pref_notifier_impl.cc(27)] pref observer found at shutdown plugins.allow_outdated
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 1
Refresh rate: 60
Refresh rate: 60
Refresh rate: 60
Refresh rate: 60
Refresh rate: 60
Refresh rate: 60
Refresh rate: 60
Refresh rate: 60
Refresh rate: 60
Refresh rate: 1
Refresh rate: 1
assert_20151129104300_1.dmp[2565]: Finished uploading minidump (out-of-process): success = yes
assert_20151129104300_1.dmp[2565]: response: CrashID=bp-048458a2-ad79-40a8-b02f-957ba2151129
assert_20151129104300_1.dmp[2565]: file ‘’/tmp/dumps/assert_20151129104300_1.dmp’', upload yes: ‘‘CrashID=bp-048458a2-ad79-40a8-b02f-957ba2151129’’
