I do not understand the following in the cuDNN installation -
Include cudnn.lib in your Visual Studio project.
a. Open the Visual Studio project and right-click on the project name.
b. Click Linker > Input > Additional Dependencies.
c. Add cudnn.lib and click OK.
Can someone explain this step by step … with screen captures if possible
Just follow the above instructions using cudnn.lib instead of cusparse.lib, for example.
If your cudnn.lib is in the same place as your cudart.lib, then the above method is all that is needed. If the cudnn.lib is somewhere else, then you will also need to update the linker search path in visual studio as well.
I don’t understand this part either.
Is it necessary to use Visual Studio to make CUDA work in Python script?
When I install dlib it says: DLIB WILL USE CUDA, but it doesn’t when I’m checking with commands:
import dlib
dlib.DLIB_USE_CUDA
it says False for me, so how can I use it on Windows 10, Python 3.7, CUDA 10.2, Dlib 19.19 ?
GPU: GTX 1050 and MX150, updated drivers on both laptops but problem is the same 😫
Open the Visual Studio project and right-click on the project name then Properties.
for this step, i think we should crear a new project to do this, do you know what directory of the new project should be?
