STEP file for Jetson Orin Nano Super Development Kit
I am looking for a STEP file for the Jetson Orin Nano Super Developer Kit
Hi jewell,
It is available at Jetson Download Center.
Thanks! Is it safe to assume then that the Jetson Orin Nano Development Kit and the Jetson Orin Nano Super Developer Kit are the same hardware?
Hello @jewell
Yes, it is correct to assume that it is the same hardware. However, I would like to clarify that you have to use the Jetson Orin Nano 8GB developer kit in order to enable the Super Mode.
Here are some instructions that you could check in order to enable it Exploring NVIDIA Jetson Orin Nano Super Mode performance using Generative AI | RidgeRun
I hope this helps!
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Super helpful, thanks!
To confirm my understanding - the Jetson Orin Nano Super will not be released as an individual stand-alone commercial module, correct? It is a software update specific to the Jetson Orin Nano 8GB development kit, and the commercial equivalent for production would remain the Jetson Orin Nano 8GB (mentioned here: Jetson Product Lifecycle | NVIDIA Developer)
