I have two kernels, after running the first, it all goes fine. if I also run the second kernel i get a segmentation fault. And the program will terminate while still in the first kernel. While it looks like the fault is coming from the second kernel.
Can anyone explain what is happening here. between the first kernel call and second kernel call i have a cudaSynchronizeThreads() so i suggest the first kernel needs to be finished before starting with the second right?
Thanks, Jordy
