I have two same AXG Xavier Edge devices. One of the devices works well (deviceA), but another one(device B) has an issue as following description:
I stream multiple CCTV cameras using GStreamer and OpenCV in python. However, I cant synchronize those videos frames from each cameras.
here is my testing code:
link
here is my edge devices A: (A works OK)
frames synchronized
here is my edge devices B: (B has issue )
Comparing two terminal outputs, B has two additional warning, as shown in figure (“white high lightened”)
I setup all the environment of devices B by myself.
I get device A from vendor ( the environment was not all setup by myself)
I think there must be some difference between those two environments, but i cant find out
(thank for your patients, hopping your help, thank you.)
