I have a simple open gl application which draws a vertical line to the hdmi output, the line moves left to right at a fixed speed.
On Jetson Orin 32Gb module the line stutters (skips a few frames) whenever I run the xrandr command.
On Jetson Nano module the line continues to run smoothly whenever I run the xrandr command.
This is an issue for us because we have another commercial application which is experiencing the same stuttering issue when we check the display output status with xrandr.
We follow the steps but do not hit the issue. Please execute sudo nvpmodel -m 0 and sudo jetson_clocks. The steps enable system at maximum performance mode. Please try and see if the issue disappears.
