I was trying to run the sudo apt-get update command on jetson nano r32.5.1 and I get the following error.
E: The repository ‘https://repo.download.nvidia.com/jetson/common r32.5 Release’ no longer has a Release file. N: Updating from such a repository can’t be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository ‘https://repo.download.nvidia.com/jetson/t210 r32.5 Release’ no longer has a Release file. N: Updating from such a repository can’t be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
$ sudo vi /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
deb https://repo.download.nvidia.com/jetson/common r32.5 main
deb https://repo.download.nvidia.com/jetson/t210 r32.5 main
I checked the apt source configuration file and it is same as the above. And apt-get update command fails.
Just to make sure, I tried to access the above urls from the browser. And both the links respond with “Not found”. Isn’t that the issue causing the above error ?
We can’t hit your errors when run apt-get update.
Please try open below link: https://repo.download.nvidia.com/jetson/
If you can open it, please try again “apt-get update”, if still got the same errors, please provide full apt update logs.
If you can’t open it, please check your network setting.
Yes. I can open the above link. But “apt-get update” still gives error.
Here is the full log
tqc_adm@titdtedge1:~$ sudo apt-get update
[sudo] password for tqc_adm:
Get:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Ign:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Get:2 file:/var/visionworks-repo InRelease
Ign:2 file:/var/visionworks-repo InRelease
Get:3 file:/var/visionworks-sfm-repo InRelease
Ign:3 file:/var/visionworks-sfm-repo InRelease
Get:4 file:/var/visionworks-tracking-repo InRelease
Ign:4 file:/var/visionworks-tracking-repo InRelease
Get:5 file:/var/cuda-repo-10-2-local-10.2.89 Release [574 B]
Get:6 file:/var/visionworks-repo Release [2,001 B]
Get:7 file:/var/visionworks-sfm-repo Release [2,005 B]
Get:8 file:/var/visionworks-tracking-repo Release [2,010 B]
Ign:9 https://repo.download.nvidia.com/jetson/common r32.5 InRelease
Ign:10 https://repo.download.nvidia.com/jetson/t210 r32.5 InRelease
Err:11 https://repo.download.nvidia.com/jetson/common r32.5 Release
Could not handshake: An unexpected TLS packet was received. [IP: 192.168.0.1 3128]
Err:13 https://repo.download.nvidia.com/jetson/t210 r32.5 Release
Hit:16 Index of /ubuntu-ports bionic InRelease
Hit:18 Index of /ubuntu-ports bionic-updates InRelease
Hit:19 Index of /ubuntu-ports bionic-backports InRelease
Hit:20 Index of /ubuntu-ports bionic-security InRelease
Reading package lists… Done
