Hi, I’m new to Jetson.
I have a Jetson Xavier NX device with JetPack 5.1.4 installed via an SD card.
I’m trying to run a VLLM server on it, but I’m not sure which container is compatible with my setup.
Here is the output of cat /etc/nv_tegra_release:
R35 (release), REVISION: 6.1, GCID: 39721438, BOARD: t186ref, EABI: aarch64, DATE: Tue Mar 4 10:13:09 UTC 2025
nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Sun_Oct_23_22:16:07_PDT_2022
Cuda compilation tools, release 11.4, V11.4.315
Build cuda_11.4.r11.4/compiler.31964100_0
Can anyone recommend a compatible VLLM container for this configuration?
Thank you for your response.
I’m just trying to understand — the documentation states that it’s possible to upgrade to a recent CUDA version.
If I update CUDA to the latest version,
will I be able to run a standard container with the latest VLLM?
Or are there other components on the host machine that I need to take into account?
