Hi Nvidia dev team,
I’m trying to add support for a time of flight sensor that outputs two data streams (DEPTH + IR) each of them on a distinct virtual channel.
The connection between sensor and Xavier AGX is performed using MIPI CSI E, 2 data lanes. Resolution of each DEPTH/IR stream is 640x480.
Now my question is, can this setup be supported on Xavier and if yes how would the device-tree look like considering that there is only one I2C sensor node for both virtual channels?
I succeed capturing only one virtual channel at a time using a devicetree based on imx185v1 and a V1 kernel driver. I also tried to configure the driver to report 640x960 resolution and setting both virtual channels on ID 0 but the frames get discarded by VI maybe due to double FS packet. This trick is working on other platforms.
Thank you,
Bogdan
