Hi
I mainly use gst-shark with gst-launch, but a pipeline with 2 nvinfer will fail with gst-launch because the unique-id needs to be set with the pipeline on pause, and gst-launch jumps directly from creating the pipeline to playing. Considering this, I will share a pipeline with gst-launch and only one nvinfer (in case you don’t want to install GstD) and then other pipelines using GStreamer Daemon to get 2 nvinfer in the pipeline. I will use the paths to my default DeepStream-4.0 installation, just change the base of the paths to use your installation.
Interlatency
videotestsrc → nvstreammux → nvvideoconvert → nvinfer → nvtracker → nvosd → nvoverlaysink
GST_DEBUG="GST_TRACER:7" GST_TRACERS="interlatency" gst-launch-1.0 \
videotestsrc ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=NV12, width=1280, height=720, framerate=30/1" ! queue ! \
nvstreammux0.sink_0 nvstreammux name=nvstreammux0 batch-size=1 batched-push-timeout=40000 width=1280 height=720 live-source=TRUE ! queue ! \
nvvideoconvert ! queue ! \
nvinfer config-file-path="/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_primary.txt" ! queue ! \
nvtracker tracker-width=240 tracker-height=200 ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so ll-config-file=/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/iou_config.txt ! queue ! \
nvdsosd process-mode=HW_MODE ! queue ! \
fakesink sync=false
output (TX2):
0:00:08.285432464 11930 0x559891e400 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvvideoconvert1_src, time=(string)0:00:00.039601327;
0:00:08.285570732 11930 0x559891e400 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue1_src, time=(string)0:00:00.031370939;
0:00:08.288424474 11930 0x5598ced1e0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvvideoconvert0_src, time=(string)0:00:00.008115991;
0:00:08.288514071 11930 0x5598ced1e0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)capsfilter0_src, time=(string)0:00:00.008230324;
0:00:08.288622420 11930 0x559891e450 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue0_src, time=(string)0:00:00.008327185;
0:00:08.288900716 11930 0x7f140040a0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvstreammux0_src, time=(string)0:00:00.008611753;
0:00:08.292366281 11930 0x5598ced140 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvinfer0_src, time=(string)0:00:00.065123729;
0:00:08.292572259 11930 0x559891e720 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue3_src, time=(string)0:00:00.065331019;
0:00:08.292614274 11930 0x559891dad0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue2_src, time=(string)0:00:00.056311407;
0:00:08.292945208 11930 0x559891e540 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvtracker0_src, time=(string)0:00:00.065702305;
0:00:08.293177490 11930 0x559891e590 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue4_src, time=(string)0:00:00.065932762;
0:00:08.293310766 11930 0x559891e590 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvdsosd0_src, time=(string)0:00:00.066095349;
0:00:08.293408075 11930 0x559891e680 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue5_src, time=(string)0:00:00.066187571;
0:00:08.293470505 11930 0x559891e680 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)fakesink0_sink, time=(string)0:00:00.066187571;
To measure other tracers just change GST_TRACERS in the pipeline. Some other tracer that might be useful for you:
Processing time: GST_DEBUG="GST_TRACER:7" GST_TRACERS="proctime" gst-launch-1.0 \
Framerate: GST_DEBUG="GST_TRACER:7" GST_TRACERS="framerate" gst-launch-1.0 \
CPU usage: GST_DEBUG="GST_TRACER:7" GST_TRACERS="cpuusage" gst-launch-1.0 \
Bitrate: GST_DEBUG="GST_TRACER:7" GST_TRACERS="bitrate" gst-launch-1.0 \
You can check the wiki for the documentation on all the tracers available as well as how to use the graphic tools:
Now for the pipelines with 2 or more nvinfer using GstD:
- Open 2 terminals
- In the first terminal launch GstD as a daemon with the tracers:
GST_DEBUG="GST_TRACER:7" GST_TRACERS="interlatency" gstd -D
- In the second terminal create the pipeline
gstd-client pipeline_create p0 \
nvstreammux0.sink_0 nvstreammux name=nvstreammux0 batch-size=1 batched-push-timeout=40000 width=1920 height=1080 live-source=TRUE ! queue ! \
nvinfer name=nvinfer1 config-file-path="/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_primary.txt" ! queue ! \
nvtracker tracker-width=640 tracker-height=368 ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so ll-config-file=/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/tracker_config.yml enable-batch-process=1 ! queue ! \
nvinfer name=nvinfer2 process-mode=secondary infer-on-gie-id=1 infer-on-class-ids="0:" batch-size=16 config-file-path="/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt" ! queue ! \
fakesink sync=false
gstd-client element_set p0 nvinfer1 unique-id 1
gstd-client element_set p0 nvinfer2 unique-id 2
gstd-client pipeline_play p0
- Output (in the first terminal)
0:04:45.176374519 12079 0x7fa44b5e80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvvideoconvert1_src, time=(string)0:00:00.070470749;
0:04:45.176488853 12079 0x7fa44b5e80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue1_src, time=(string)0:00:00.061132200;
0:04:45.176952816 12079 0x7fa44b5ed0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue0_src, time=(string)0:00:00.033056424;
0:04:45.177282380 12079 0x7ecc0038a0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvstreammux0_src, time=(string)0:00:00.033277477;
0:04:45.180339114 12079 0x7fa44b6280 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvvideoconvert0_src, time=(string)0:00:00.009281654;
0:04:45.180463016 12079 0x7fa44b6280 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)capsfilter0_src, time=(string)0:00:00.009765969;
0:04:45.182649935 12079 0x7fa44b6140 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvinfer1_src, time=(string)0:00:00.095506593;
0:04:45.182812237 12079 0x558c84bd90 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue2_src, time=(string)0:00:00.085548818;
0:04:45.182814317 12079 0x7fa44b61e0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue3_src, time=(string)0:00:00.095637920;
0:04:45.183806658 12079 0x7fa44b6230 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvtracker0_src, time=(string)0:00:00.096674068;
0:04:45.183885697 12079 0x7fa44b60f0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue4_src, time=(string)0:00:00.096768947;
0:04:45.183953504 12079 0x7fa44b60f0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvinfer2_src, time=(string)0:00:00.096840754;
0:04:45.184064063 12079 0x7fa44b5f70 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue5_src, time=(string)0:00:00.096942929;
0:04:45.184150942 12079 0x7fa44b5f70 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)nvdsosd0_src, time=(string)0:00:00.097017488;
0:04:45.184234301 12079 0x7fa44b5f20 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)queue6_src, time=(string)0:00:00.097105679;
0:04:45.184277213 12079 0x7fa44b5f20 TRACE GST_TRACER :0:: interlatency, from_pad=(string)videotestsrc0_src, to_pad=(string)fakesink0_sink, time=(string)0:00:00.097105679;
