Thanks for the advice. I was able to preview the image from the sensor but it seems that it lacks of sharpness. I contacted the camera vendor which is one of your camera partners for the ISP tuning of the monochrome sensor that we purchased from them and received the following answer :
We attempted the ISP tuning for monochrome sensors but found out that Nvidia do not fully support the ISP pipeline, which resulted to chroma artifacts. For this reason, unfortunately, we did not release the ISP tuning for the monochrome sensors.
It looks like that we cannot use monochrome sensors with Nvidia Jetson platforms for the moment due to above limitation if it’s true. Do you confirm?
BTW, do you have detail information about the chroma artifacts.
The question has been forwarded to the support team of the camera partner in contact. I will update you whenever the required information is available.
Unfortunately, I was asked not to share the captured images of the chroma artifacts (which can only be shared under NDA and in order to avoid confusion with potential on-going discussion(s) btw the both parties).
