Suspend disorder
Hi,I using jetson AGX Orin version 35.1, I went to the upper right corner of the screen and clicked on “suspend”. The system restarted or shut down. What is the reason?
Dec 12 23:59:44 nvidia-desktop nvfancontrol[843]: NVFAN ERROR: FAN1: Cannot turn the fan on even the PWM is set to 255, please check if the fan is faulty.
Dec 12 23:59:44 nvidia-desktop nvfancontrol[843]: message repeated 38 times: [ NVFAN ERROR: FAN1: Cannot turn the fan on even the PWM is set to 255, please check if the fan is faulty.]
Dec 12 23:59:44 nvidia-desktop gnome-shell[9970]: g_dbus_connection_emit_signal: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
Dec 12 23:59:44 nvidia-desktop gnome-shell[9970]: cr_parser_new_from_buf: assertion 'a_buf && a_len' failed
Dec 12 23:59:44 nvidia-desktop gnome-shell[9970]: cr_declaration_parse_list_from_buf: assertion 'parser' failed
Dec 12 23:59:44 nvidia-desktop kernel: [  567.366274] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD data byte 1
Dec 12 23:59:44 nvidia-desktop kernel: [  567.366290] snd_hda_codec_hdmi hdaudioC0D0: HDMI: out of range MNL 13
Dec 12 23:59:44 nvidia-desktop rtkit-daemon[9233]: Supervising 6 threads of 2 processes of 2 users.
Dec 12 23:59:44 nvidia-desktop rtkit-daemon[9233]: Successfully made thread 10534 of process 9628 owned by '1000' RT at priority 5.
Dec 12 23:59:44 nvidia-desktop rtkit-daemon[9233]: Supervising 7 threads of 2 processes of 2 users.
Dec 12 23:59:45 nvidia-desktop systemd[1]: systemd-timedated.service: Succeeded.
Dec 12 23:59:46 nvidia-desktop tracker-store[9306]: OK
Dec 12 23:59:46 nvidia-desktop systemd[9218]: tracker-store.service: Succeeded.
Dec 12 23:59:47 nvidia-desktop systemd[1]: Reached target Sleep.
Dec 12 23:59:47 nvidia-desktop systemd[1]: Condition check resulted in Record successful boot for GRUB being skipped.
Dec 12 23:59:47 nvidia-desktop systemd[1]: Condition check resulted in GRUB failed boot detection being skipped.
Dec 12 23:59:47 nvidia-desktop systemd[1]: Starting Suspend...
Dec 12 23:59:47 nvidia-desktop systemd-sleep[10537]: Suspending system...
Dec 12 23:59:47 nvidia-desktop kernel: [  569.791598] PM: suspend entry (deep)
Dec 12 23:58:18 nvidia-desktop systemd-modules-load[298]: Inserted module 'nvmap'
Dec 12 23:58:18 nvidia-desktop kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
Dec 12 23:58:18 nvidia-desktop systemd[1]: Mounted Huge Pages File System.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Mounted POSIX Message Queue File System.
Dec 12 23:58:18 nvidia-desktop kernel: [    0.000000] Linux version 5.10.104-tegra (n@ubuntu) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #10 SMP PREEMPT Sat Dec 10 06:46:54 PST 2022
Dec 12 23:58:18 nvidia-desktop kernel: [    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
Dec 12 23:58:18 nvidia-desktop systemd[1]: Mounted RPC Pipe File System.
Dec 12 23:58:18 nvidia-desktop kernel: [    0.000000] OF: fdt:  - 80000000 ,  c0000000
Dec 12 23:58:18 nvidia-desktop systemd[1]: Mounted Kernel Debug File System.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Mounted Kernel Trace File System.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Set the console keyboard layout.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Create list of static device nodes for the current kernel.
Dec 12 23:58:18 nvidia-desktop systemd[1]: nvfb-udev.service: Succeeded.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished NVIDIA specific first-boot udev script.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Remount Root and Kernel File Systems.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Flush Journal to Persistent Storage...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Load/Save Random Seed...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Create System Users...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Load/Save Random Seed.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Flush Journal to Persistent Storage.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Create System Users.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Create Static Device Nodes in /dev...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Create Static Device Nodes in /dev.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Reached target Local File Systems (Pre).
Dec 12 23:58:18 nvidia-desktop systemd[1]: Reached target Local File Systems.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Enable support for additional executable binary formats...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Set console font and keymap...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Preprocess NFS configuration...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Dec 12 23:58:18 nvidia-desktop systemd-modules-load[298]: Inserted module 'nvgpu'
Dec 12 23:58:18 nvidia-desktop systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting Create Volatile Files and Directories...
Dec 12 23:58:18 nvidia-desktop systemd[1]: Starting udev Kernel Device Manager...
Dec 12 23:58:18 nvidia-desktop systemd-modules-load[298]: Inserted module 'pwm_fan'
Dec 12 23:58:18 nvidia-desktop systemd[1]: Finished Set console font and keymap.
Dec 12 23:58:18 nvidia-desktop systemd[1]: nfs-config.service: Succeeded.
We don’t observe the issue. Could you try command line:
$ sudo systemctl suspend
See if you can enter suspend mode by running the command.
Hi,running the command. cannot enter suspend mode, the system restarts.
Please run the commands and share the prints for reference:
nvidia@tegra-ubuntu:~$ cat /proc/device-tree/chosen/ids
nvidia@tegra-ubuntu:~$ sudo i2cdump -y 0 0x56
Thank you, this issue has been resolved. It may be that I modified the spe_t234.bin file and when I clicked on the “suspend” function, it caused the system to restart.
