Suspend not working on Ubuntu 26.04 /black screen on resume with Nvidia driver version 595
Hello to all,
I recently installed Ubuntu 26.04 and then performed sudo apt upgrade but after that I cannot “suspend” ubuntu session. WHen I try to do it, the screen goes black but the power button doesnt have blinking light. The system is in a hung state and a hard reboot holding the power button is required. I also have windows11 on another drive but it doesn’t have this problem. This is my hardware and driver info regarding GPU:
output of sudo lshw -C display
description: VGA compatible controller
product: TU104GL [Quadro RTX 4000]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=nvidia latency=0 mode=1920x1080 resolution=1920,1080 visual=truecolor xres=1920 yres=1080
resources: irq:46 memory:f2000000-f2ffffff memory:d0000000-dfffffff memory:e0000000-e1ffffff ioport:8000(size=128) memory:c0000-dffff
output of inix -G
Graphics:
  Device-1: NVIDIA TU104GL [Quadro RTX 4000] driver: nvidia v: 595.84
  Display: x11 server: X.Org v: 21.1.22 with: Xwayland v: 24.1.10 driver: X:
    loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa
    gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: nvidia,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 595.84
    renderer: Quadro RTX 4000/PCIe/SSE2
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings
    gpu: nvidia-settings,nvidia-smi x11: xdriinfo, xdpyinfo, xprop, xrandr
output of nvidia-smi
Thu Jul 30 20:53:38 2026
| NVIDIA-SMI 595.84                 Driver Version: 595.84         CUDA Version: 13.2     |
|   0  Quadro RTX 4000                Off |   00000000:03:00.0  On |                  N/A |
| 30%   55C    P8             15W /  125W |     424MiB /   8192MiB |     20%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A            3124      G   /usr/lib/xorg/Xorg                      129MiB |
|    0   N/A  N/A            5525      G   cinnamon                                 69MiB |
|    0   N/A  N/A           16908      G   .../8107/usr/lib/firefox/firefox        213MiB |
I did not change any other setting except sudo apt update and sudo apt upgrade. The suspend command was working before apt upgrade.
What should I do to fix this issue?
Thank you and regards
Anirudh Nehra
I found suspend sometime work if using cinnamon default power setting(5 min to suspend if left idle)
However the system wakes-up to black screen and nothing can be done. Only hard reboot brings up login screen.
Regards
Anirudh
I reproduced a related Ubuntu 26.04 black-screen-after-resume symptom with nvidia-driver-595-open 595.84 on a GTX 1650 Mobile and KDE Plasma Wayland. The useful distinction was the power-management integration, not a replacement of the driver binary.
The initial package state was:
PreserveVideoMemoryAllocations: 1
UseKernelSuspendNotifiers: 0
/proc/driver/nvidia/suspend: present
nvidia-suspend.service / nvidia-resume.service: enabled
This path runs nvidia-sleep.sh, which switches to VT 63. At that point KWin logged atomic commit failed: Permission denied and temporary loss of /dev/dri/renderD128; earlier cycles sometimes failed to recover the display.
For Open modules, I enabled the documented kernel notifier path:
options nvidia NVreg_UseKernelSuspendNotifiers=1
Then I disabled the /proc suspend/resume/hibernate units and rebooted. The resulting S3 deep cycle used nv_pm_notifier, did not switch VTs, did not produce the KWin atomic denial, and Plasma resumed normally. VRAM preservation remained enabled.
This is a workaround and evidence for a packaging/integration issue: the shared Ubuntu nvidia-kernel-common-595 configuration appears to select the /proc/VT path for Open, even though Open supports the notifier path. I have sanitized NVIDIA bug reports and before/after traces available if NVIDIA requests them.
