For development purposes, I’d like to purchase a Fermi GPU on top to sit aside the current 9600. However, I don’t want to use both at the same time, but rather each separately so that I can test performance on both of them individually. Obviously, I could physically swap them in and out, but that would be a pain.
So basically, I’m wondering if there’s a ‘software’ switch that would only recognize one of the GPUs at boot time?
Good to speak to you here cbuchner1 - finally managed to drag myself into learning some GPU stuff. I’m bracing myself!
It’s so I can switch between them both when testing my code. I want to run code on them individually to see the differences.
Not to mention seemingly dangerous if I disable the card and the monitor blacks out without the other card kicking in. I guess windows has some safety net in that case though (which I might need if I experiment with OpenCL or some other environments).
