hi,
i am editing syncsensor sample to display the 2 stream images by using preview consumer thread, but it
CUresult cuResult = cuEGLStreamConsumerConnect(&m_cuStreamLeft, m_leftEGLOutputStream->getEGLStream()); ScopedCudaEGLStreamFrameAcquire left(m_cuStreamLeft); CUeglStreamConnection& m_connection; CUstream m_stream; CUgraphicsResource m_resource; CUeglFrame m_frame; CUresult r = cuEGLStreamConsumerAcquireFrame(&m_connection, &m_resource, &m_stream, -1); cuGraphicsResourceGetMappedEglFrame(&m_frame, m_resource, 0, 0);
PRODUCER_PRINT("Launching consumer thread\n"); std::vector<EGLStreamKHR> eglStreams; eglStreams.push_back(m_leftEGLOutputStream->getEGLStream()); eglStreams.push_back(m_rightEGLOutputStream->getEGLStream()); PreviewConsumerThread consumerThread(g_display.get(), eglStreams, PreviewConsumerThread::LAYOUT_SPLIT_VERTICAL, true /* Sync stream frames */); PROPAGATE_ERROR(consumerThread.initialize()); consumerThread.setLineWidth(1); consumerThread.setLineColor(1.0f, 0.0f, 0.0f); // Wait until the consumer is connected to the streams. PROPAGATE_ERROR(consumerThread.waitRunning());
below shows the error while running.
Capture Session: 0x55a8d27910 Stream Settings: 0x55a8d27950 EGL Stream Settings: 0x55a8d6ec80 PRODUCER: Creating left stream. EGL Output Stream Left: 0x55a8d2a5a0 PRODUCER: Creating right stream. EGL Output Stream Right: 0x55a8ce2590 PRODUCER: Launching StereoWorker Initializing CUDA CONSUMER: Connecting CUDA consumer to left stream CONSUMER: Connecting CUDA consumer to right stream CONSUMER: Waiting for Argus producer to connect to left stream. Request: 0x55a8ce8a80 Source Settings: 0x55a8ce1a00 Left Stream Settings: 0x55a8ce1a40 Right Stream Settings: 0x55a8ce1a20 PRODUCER: Starting repeat capture requests. CONSUMER: Waiting for Argus producer to connect to right stream. CONSUMER: Streams connected, processing frames. PRODUCER: Launching consumer thread PREVIEW CONSUMER: Creating OpenGL context. PREVIEW CONSUMER: Connecting to EGLStream(s). Error generated. /home/nvidia/git/src/ros/src/camera/argus_camera_driver/argus/samples/utils/PreviewConsumer.cpp, threadInitialize:123 Unable to connect GL as consumer Error generated. /home/nvidia/git/src/ros/src/camera/argus_camera_driver/argus/samples/utils/Thread.cpp, threadFunction:126 (propagating) Error generated. /home/nvidia/git/src/ros/src/camera/argus_camera_driver/src/argus_syncsensor.cpp, threadExecute:202 (propagating) Error generated. /home/nvidia/git/src/ros/src/camera/argus_camera_driver/argus/samples/utils/Thread.cpp, threadFunction:132 (propagating)
if i remove the preview consumer, then the syncsensor program as per normal.
can i just use this
CUeglFrame m_frame;
to feed to preview consumer thread?
please advise.
