So I was able to dmesg when running a game and I noticed that when the lag happens, this line is printed about 1600 times:
[ +0,000005] nvidia 0000:09:00.0: [drm:drm_ioctl] comm=“kwin_wayland” pid=3759, dev=0xe201, auth=1, DRM_IOCTL_MODE_GETPROPERTY
I have rebuilt the kernel to see the call stack. This is what the stack is:
[ +0,000005] CPU: 4 UID: 1000 PID: 3742 Comm: kwin_wayland Tainted: P OE 6.11.0-19-generic #19
[ +0,000003] Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ +0,000001] Hardware name: System manufacturer System Product Name/PRIME B450-PLUS, BIOS 3604 02/25/2022
[ +0,000002] Call Trace:
[ +0,000001] <TASK>
[ +0,000002] show_stack+0x49/0x60
[ +0,000003] dump_stack_lvl+0x5f/0x90
[ +0,000003] drm_ioctl+0x2bb/0x5a0
[ +0,000004] ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ +0,000008] nv_drm_ioctl+0x42/0x450 [nvidia_drm]
[ +0,000005] ? srso_return_thunk+0x5/0x5f
[ +0,000002] ? __check_object_size.part.0+0x3a/0xe0
[ +0,000003] ? srso_return_thunk+0x5/0x5f
[ +0,000003] ? _copy_to_user+0x41/0x60
[ +0,000002] ? drm_ioctl+0x419/0x5a0
[ +0,000004] __x64_sys_ioctl+0xa3/0xf0
[ +0,000004] x64_sys_call+0x121b/0x22b0
[ +0,000002] do_syscall_64+0x7e/0x170
[ +0,000002] ? nv_drm_ioctl+0x42/0x450 [nvidia_drm]
[ +0,000002] ? syscall_exit_to_user_mode+0x4e/0x250
[ +0,000004] ? srso_return_thunk+0x5/0x5f
[ +0,000002] ? do_syscall_64+0x8a/0x170
[ +0,000002] ? __audit_syscall_exit+0xbb/0x100
[ +0,000002] ? syscall_exit_work+0x116/0x140
[ +0,000002] ? syscall_exit_to_user_mode_prepare+0x38/0x80
[ +0,000003] ? do_syscall_64+0x8a/0x170
[ +0,000003] ? __audit_syscall_exit+0xbb/0x100
[ +0,000003] ? syscall_exit_to_user_mode_prepare+0x38/0x80
[ +0,000002] ? srso_return_thunk+0x5/0x5f
[ +0,000003] ? sysvec_apic_timer_interrupt+0x57/0xc0
[ +0,000003] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ +0,000003] RIP: 0033:0x7eaf8192eb1d
[ +0,000002] Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 0>
[ +0,000002] RSP: 002b:00007ffc56c96fe0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ +0,000003] RAX: ffffffffffffffda RBX: 0000000000000017 RCX: 00007eaf8192eb1d
[ +0,000002] RDX: 00007ffc56c97070 RSI: 00000000c04064aa RDI: 0000000000000017
[ +0,000001] RBP: 00007ffc56c97030 R08: 0000000000000007 R09: 0000565592aa3010
[ +0,000002] R10: 00007eaf81a11ac0 R11: 0000000000000246 R12: 00007ffc56c97070
[ +0,000002] R13: 00000000c04064aa R14: 0000000000000017 R15: 000056559483f6f0
Calling drm_ioctl 1600 times in a row I think is the reason of the lag spike. Why is it called so many times?
