• Hardware - L4
• Network Type - TAO classification_pyt / fan_small_12_p4_hybrid
I’m working through the classification_pyt notebook and am stuck with an error.
The notebook cell is:
print("Train Classification Model")
!tao model classification_pyt train \
-e $SPECS_DIR/train_cats_dogs.yaml \
-r $RESULTS_DIR/classification_experiment \
-g $NUM_GPUS \
model.init_cfg.checkpoint=/workspace/tao-experiments/pretrained_fan_hybrid_small/pretrained_fan_classification_imagenet_vfan_hybrid_small/fan_hybrid_small.pth \
train.train_config.runner.max_epochs=$EPOCHS
It’s failing with:
2024-07-09 21:29:23,283 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
File "/usr/local/lib/python3.10/dist-packages/requests/adapters.py", line 633, in send
conn = self.get_connection_with_tls_context(
File "/usr/local/lib/python3.10/dist-packages/requests/adapters.py", line 489, in get_connection_with_tls_context
conn = self.poolmanager.connection_from_host(
File "/usr/local/lib/python3.10/dist-packages/urllib3/poolmanager.py", line 246, in connection_from_host
return self.connection_from_context(request_context)
File "/usr/local/lib/python3.10/dist-packages/urllib3/poolmanager.py", line 258, in connection_from_context
raise URLSchemeUnknown(scheme)
urllib3.exceptions.URLSchemeUnknown: Not supported URL scheme http+docker
This is reproducible in the shell with:
tao model classification_pyt run /bin/bash
I’m searched the forums and would add the following:
- I’m running requests-2.31.0 (see here)
pip show requests
Version: 2.31.0
Summary: Python HTTP for Humans.
Home-page: https://requests.readthedocs.io
Author: Kenneth Reitz
Author-email: me@kennethreitz.org
License: Apache 2.0
Location: /home/****/miniconda3/envs/tao-launcher/lib/python3.7/site-packages
Requires: certifi, charset-normalizer, idna, urllib3
Required-by: wandb
- Docker is being run as a user, not root
Output of tao info:
$ tao info
Configuration of the TAO Toolkit Instance
task_group: ['model', 'dataset', 'deploy']
format_version: 3.0
toolkit_version: 5.3.0
published_date: 03/14/2024
Full exception output:
2024-07-09 21:47:44,850 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 205, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/local/lib/python3.10/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/local/lib/python3.10/dist-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 228, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 602, in get
return self.request("GET", url, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/requests/adapters.py", line 637, in send
raise InvalidURL(e, request=request)
requests.exceptions.InvalidURL: Not supported URL scheme http+docker
File "/usr/local/bin/tao", line 8, in <module>
sys.exit(main())
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_cli/entrypoint/tao_launcher.py", line 134, in main
instance.launch_command(
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_cli/components/instance_handler/local_instance.py", line 357, in launch_command
docker_handler = self.handler_map[
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_cli/components/instance_handler/local_instance.py", line 203, in handler_map
handler_map[handler_key] = DockerHandler(
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_cli/components/docker_handler/docker_handler.py", line 92, in __init__
self._docker_client = docker.from_env()
File "/usr/local/lib/python3.10/dist-packages/docker/client.py", line 84, in from_env
return cls(
File "/usr/local/lib/python3.10/dist-packages/docker/client.py", line 40, in __init__
self.api = APIClient(*args, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 188, in __init__
self._version = self._retrieve_server_version()
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 212, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: Not supported URL scheme http+docker
