I’m running the entire classification process in the notebook and I’m getting the onnx model. After resolving the error “Initializer onnx::MatMul_3870 appears in graph inputs and will not be treated as a constant value/weight.” with remove_initializer_from_input.py,
I’m unable to correctly classify images presented to the camera.
I substituted the TAO onnx model with the “resnet18-v1-7” model from onnx, and my program works fine. It classifies everything I present to it.
I checked the model’s input:
input_1, Shape: [‘batch’, 3, 224, 224]
and the image format I’m passing to it.
(np.shape(frame_normalized)
1, 3, 224, 224)
So I’m wondering if the problem is known, and what solution I could implement.
Thank’s
Sylvain Bolduc
Hi @sylvain.bolduc I’ve moved this to the Tao forum so the right team can help you out.
Best,
Sophie
Which notebook did you run? Can you share logs or .ipynb? The notebook should run smoothly instead of error.
I created a share point with the fully executed notebook, along with all the useful files.
TAO_classification
I understand that the model gives a slightly higher than 50% correct answer in the evaluation. But when I try to use it, it only gives one answer. Everything is a dog. But when I use the Resnet model and its classes, the little program works well. The TAO philosophy appeals to me a lot because I’m not an AI expert, but I’d like to use it for simple applications, as does the idea of working with pre-trained networks and finetuning them. Thank you.
