GPU
• DeepStream Version
6.1
• TensorRT Version
8.2.5.1
512.95
I have trained a classifier model (darknet53 backbone) with the newest version of TAO (3.22.05), to classify detections from PeopleNet (v2.6) into gender (Female/Male). The classifier works as expected when running inference on some test data with tao classifier inference.
However, when the model is exported as .etlt format, and deployed to DS, the outputs are completely broken with only one label getting predicted with 100% confidence;
The model is deployed with the nvinfer_config.txt file generated from the --gen_ds_config flag in the tao classification export command as below:
[property]
net-scale-factor=1.0
batch-size=1
offsets=103.939;116.779;123.68
infer-dims=3;224;224
tlt-encoded-model=gender.etlt
tlt-model-key=06052019
labelfile-path=gender_label.txt
network-type=1
num-detected-classes=2
uff-input-order=0
output-blob-names=predictions/Softmax
uff-input-blob-name=input_1
model-color-format=1
maintain-aspect-ratio=0
output-tensor-meta=0
process-mode=2
network-mode=0
gie-unique-id=3
operate-on-gie-id=1
classifier-threshold=0.0
When inspecting the raw output tensor by setting output-tensor-meta=1 the results are the same, with only one label being predicted by 100%.
Model .etlt file at the following link: https://transfer.sh/(/ELcTKy/gender.etlt).zip
Config and label file attached.
gender_config.txt (461 Bytes)
gender_labels.txt (12 Bytes)
Any help is greatly appreciated,
/M
